Old 10-03-2002, 12:29 AM   #1
drdingo21
drdingo21's Avatar
what gauge cluster will fit?
i have a 94 ex that i broke when installing the indglo gauges. my question is what other gauge cluster will fit in here? i found some 97 gauge cluster and they look the same up front but will the hook up in the back, thanks!
Old 10-03-2002, 03:50 PM   #2
ShagginJet
ShagginJet's Avatar
92-95 ONLY
Old 10-03-2002, 06:09 PM   #3
drdingo21
drdingo21's Avatar
thats what i thought :( isn't any year SI will fit also?
Old 10-03-2002, 06:21 PM   #4
ShagginJet
ShagginJet's Avatar
the 92-95 si should fit, maybe some wire mods that need to be done....
does the current one you have have a tach?
RECENTLY UPDATED!!! 5-20-04
Old 10-03-2002, 06:31 PM   #5
drdingo21
drdingo21's Avatar
yea its an ex manual. everything works except the gas needle wich i broke...
Old 10-03-2002, 06:54 PM   #6
ShagginJet
ShagginJet's Avatar
ouch, i think you can buy the needles for less the it'd cost to replacethe unit through like ebay. if you broke the actual needle, that should be cheap. if it's the unit with the gas and temp, probably about 75$, the whole used unit is about 150$.
Old 10-03-2002, 07:27 PM   #7
drdingo21
drdingo21's Avatar
well i pulled the needles out instead of just sliding the gauge over it. so the lone meatl rod broke off inside the gas gauge... motor thing
Old 10-03-2002, 07:32 PM   #8
ShagginJet
ShagginJet's Avatar
You're going ot have to replace that unit peice of the cluster, you can get that from the honda dealership, be ready to pay.
Old 10-03-2002, 07:54 PM   #9
drdingo21
drdingo21's Avatar
bah, ill go to a junkyard and tear that pice out of any gauge cluster i can find
Old 10-03-2002, 07:57 PM   #10
ShagginJet
ShagginJet's Avatar
good luck, while you're there, if you find a good condition cluster with tach for an 88+, e-mail me, i'll buy it if the price is right
Old 10-04-2002, 03:29 PM   #11
get a new gauge cluster.....$150? i dunno where you shop at, but maybe you should find a new place to purchase your parts.
you can probably pick up a 92-95 gauge cluster for $60 @ a junkyard.
Old 10-04-2002, 03:38 PM   #12
ShagginJet
ShagginJet's Avatar
That's cause you found it at a junkyard... in LA all the junk yards were tapped out, DRY, had to buy one on ebay. It was a rough number anyways.
Old 10-04-2002, 03:38 PM   #13
ShagginJet
ShagginJet's Avatar
(hybrid) BTW... I really like your car, sw33t!!
Old 10-04-2002, 03:44 PM   #14
drdingo21
drdingo21's Avatar
no junk yard around here has one eihter...
Old 10-04-2002, 03:52 PM   #15
you can use a 96-00 civic cluster or a 94-01 integra cluster.....just takes some trimming here and there and making custom brackets for it to bolt up - and some rewiring. its a hassle, but it can be done.
