Old 09-11-2002, 06:17 PM   #1
drdingo21
drdingo21's Avatar
damn!!!!!!
I was replacing my gagues on my civic with new white ones and when i was pulling the little needle off the gas gauge i broke the little bar that holds it!! What the hell should i do???
Old 09-11-2002, 07:41 PM   #2
I'd check the junkyard for a new gauge.
Old 09-11-2002, 09:32 PM   #3
what he said. ^^^
Old 09-11-2002, 10:21 PM   #4
drdingo21
drdingo21's Avatar
should i get a whole new gauge or just that little thing that drives the the gas gauge? also what if i can't fine a 92-95 civic ex manual???
Old 09-12-2002, 01:57 AM   #5
I'd get the whole gauge if you broke the part I'm thining about.
If you can't find it, check
www.recycler.com
www.partstrader.com
www.haprecycling.com (I think)
There are many more online recycling things too.
Old 09-12-2002, 10:37 AM   #6
you can use one out of an Si as well, or an LX.....
also look on www.ebay.com
Old 09-12-2002, 01:47 PM   #7
drdingo21
drdingo21's Avatar
sigh... no one around here has any.... im gonna look through those links later tonight, thanks guys... The gauges i bought are revers indaglow should i just lay them over the top of the old ones? the instruction i got sucked
Old 09-12-2002, 06:40 PM   #8
yes you should, but you broke the needle right? no needle is NOT OK!
Old 09-12-2002, 11:07 PM   #9
drdingo21
drdingo21's Avatar
well see i took the olds ones out and put the new ones in..thats how i broke the dam needle!!! then i figured out your not supposed to do that..
Old 09-13-2002, 01:44 AM   #10
hanzer
you are supposed to take the screws out of the gauges and then place the new gauges over the stock ones. Put the screws back in, and make sure there are no light leaks. You should have been able to do this without removing your gauges. That's too bad that they broke, mine was a piece of cake to install. Hope you find other replacements.
Old 09-13-2002, 01:56 AM   #11
Do not even touch or move the needles during the install. If they do get bumped, put them back exactly how you found them.
Old 09-13-2002, 04:13 AM   #12
drdingo21
drdingo21's Avatar
well its too late for that. i yanked them out now my speedomitor is off im pretty sure my tach is off ang i completly broke my fuel gaguge...sigh...
Old 09-13-2002, 01:19 PM   #13
If your whole cluster is messed up, check Ebay or the other sites that were given to you. Clusters pop up now and then.
Old 09-17-2002, 02:03 AM   #14
fadednite
yeah you dont need to remove the old gauges, just lay the new ones over it and put the screws on top. Don't remove the needles, though its too late. Check ebay. I always see gauge clusters there, cheap too.
Old 09-17-2002, 03:09 PM   #15
Whtehnda93DXSdn
It has 4 Doors...
Whtehnda93DXSdn's Avatar
go get a new cluster for sure..I did the same thing over 2yrs ago and you learn from your mistakes and not finding out How To before hand.
you could also try www.aaforeign.com as that's where I got mine from to replace my broken one.
good luck on the fix and remember needles don't come off...
Another good forum site:
Tuners Alliance
