Old 08-29-2004, 01:23 PM   #1
mcruz
mcruz's Avatar
internal mods?
Hey guys need some imput on what internal mods I can start picking up to help push psi to 10-15, if you guys or girls have ideas let me know please thanks a lot.
mcruz is offline   Reply With Quote
Old 08-29-2004, 04:39 PM   #2
4drmadness
well you could choose a set of new rods and pistons. that will help along w/ getting lower compression pistons that will help for the increased boost. Check out www.raceeng.com
Old 08-29-2004, 05:04 PM   #3
mcruz
mcruz's Avatar
Sweet thanks, I will look into them,
FOCUSHARD
Old 08-29-2004, 06:01 PM   #4
VR4_Craver
Banned
yea get pistons and rods.....Check for eagle rods that is what everyone one is using.
Old 08-29-2004, 11:22 PM   #5
mcruz
mcruz's Avatar
i check that site got good stuff, i hear thAT A thicker gasket is works too, true or false
FOCUSHARD
Old 08-30-2004, 12:17 AM   #6
thicker gasket for lower compression a little bit, yeah.
Old 08-30-2004, 10:54 AM   #7
soundspeed
soundspeed's Avatar
Check out JE Pistons, or Arias Pistons
Old 08-30-2004, 05:48 PM   #8
CivicSlug
CivicSlug's Avatar
Eagle forged rods, SRP forged pistons w/ MLS high boost gasket works well together.
CivicSlug is offline   Reply With Quote
Old 08-30-2004, 11:17 PM   #9
what engine?
If it's for a d16 there's a dude over on honda-tech that sells a nice combo that lets you run around that boost with no other mods (besides fuel obviously) you have to notch the block but you have to do that with any rod that I know of.
http://www.honda-tech.com/zerothread?id=267641
It's a good package.
Old 08-31-2004, 08:15 PM   #10
mcruz
mcruz's Avatar
Ok so pistons & rods and a thicker gasket, ok I will start looking into them start picking them up and really get ready fot next summer thank, any other ideas let me know, turboD16 sweer
FOCUSHARD
Old 08-31-2004, 10:53 PM   #11
you dont need a thicker head gasket. the pistons you get will come in different compression ratios. 9:1 would be fine.
Old 09-01-2004, 10:47 AM   #12
mcruz
mcruz's Avatar
so you cant do thicker casket and pistons i dont understand, thanks
FOCUSHARD
Old 09-01-2004, 12:34 PM   #13
exactly
What's the point of modifying the internals with low compression pistons and turn around get a thicker head gasket. Pointless to me. Drop the compression to whatever you like (I prefer 9.5:1) then get a stock Honda spec Cometic head gasket. You will run into timing problems on thicker head gasket since the cam will be off. It's fixable by a few ways tho, the most common is using an adjustable cam gear.
D-series turbos makes a lot of torque because of long stroke. If you bore the cylinders out, be ready to sleeve it.
Goodluck
Next time, please ask these types of question on the turbo forum where it belongs.
Old 09-01-2004, 12:37 PM   #14
mcruz
mcruz's Avatar
ok no thicker gasket , thanks guy
FOCUSHARD
Old 09-01-2004, 10:19 PM   #15
i agree 9.5:1 is better.
endyne makes some nice pistons(well they just modify custom wisecos)
