Old 06-08-2004, 10:41 PM   #1
Seafoam
I'll be blunt... Get a can.
This stuff is awesome. Engine runs SO much smother than it did before.
(I did run 2 cans of fuel system cleaner through the tank beforehand...just to clean up a little bit)
As soon as you pour the 1/3 of it it into the booster hose (funnel needed..and you'll need to keep pulling the throttle cable so the engine doesnt die...duh) you'll shoot a crap load of white smoke........and I mean a crap load.
It was neat
Then I added another 1/3 of it to the gas tank and the other 1/3 to the crank case (oil filler hole).
After that I just drove it around for 10mins until all the white smoke was gone (spirited driving).
When I got home I changed the old crappy oil (which wasnt really that dirty...), plugs (since the old ones were bombarded w/ carbon deposits shooting past them at mach 4) and fuel filter (because it's never been done................dirty in there).
Im very pleased w/ this stuff and my car seems to be as well.
(Only downside to this maint. is that I found that my outter cv boot and axle took a shit and Im now in the process of fighting w/ the lower ball joint to replace the axle....it sucks)
(A better how-to: http://auto.snowsuperstars.com/seafoam.html )
The picture at the bottom of the white smoke doesnt do it justice....my neighbors got pissed because of all the smoke I had shooting out.)
Oh...use it at your own risk: After using it you could find leaks or other crap.
Old 06-09-2004, 02:57 AM   #2
i've been wanting to do this, but with 115,000miles i'm scared.
my damn axle boot is f'd too!
thanks for the info
Old 06-09-2004, 07:27 AM   #3
i use the lucas tuneup in a bottle stuff. it's only $3 andafter i run it thru a tank of gas you can see the pistons silver. i ran it in my accord a few times, the first time was after 150k miles and i was quite impressed with it
Old 06-09-2004, 10:53 AM   #4
w/ 115k Id be a little scared too...but you could try running carb cleaner through it first and a couple bottles of regular system cleaner and see what happens. Then maybe seafoam.
I just dont like lucas products... Ive seen and heard bad things, mostly from my cousin who is a ford-fanatic and builds crazy muscle engines
Old 06-09-2004, 05:30 PM   #5
ever seen the lucas oil stabilizer test things they have at CAP? it's a series of gears attached to a hand crank that are in regular oil and then there's another set that has 20% lucas oil stabilizer. When you turn it you can actually see the oil move up through the gears. It's pretty neat.
Old 06-09-2004, 09:11 PM   #6
lucas baaaaad
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Old 06-09-2004, 09:54 PM   #7
great link!
Old 06-09-2004, 10:00 PM   #8
WOW, somebody has way too much free time, but i would have never guessed those results...
Old 06-09-2004, 11:03 PM   #9
sicones
sicones's Avatar
what is "seafoam"????
Old 06-10-2004, 05:52 AM   #10
super-mega carb/injector cleaner
it removes probably close to 90-100% of all carbon deposits when ran through all 3 locations.
(It has a warning on it )
Old 06-10-2004, 01:20 PM   #11
sicones
sicones's Avatar
where can you get this
Old 06-10-2004, 01:23 PM   #12
sicones
sicones's Avatar
i'll have my friend use it first
Old 06-11-2004, 11:30 AM   #13
I got it at murrays discount auto...autozone doesnt carry it
try pepboys or napa
Old 06-12-2004, 12:00 AM   #14
This is fucking great man..... I'm gonna try this soon. Gotta got to Napa to see if they have it.....
Old 06-12-2004, 02:00 PM   #15
question though, i just just put plugs in my car so does that mean that the seafoam will kill them?
Old 06-12-2004, 03:00 PM   #16
napa should have it, the one here does
Old 06-14-2004, 04:57 PM   #17
hmm still wondering if seafoam is going to kill my brand new plugs because i want to try it and i don't want to have to replace new plugs.
Old 06-14-2004, 08:10 PM   #18
you really should change them after doing it.
Ive learned to keep my old plugs around for about a month after changing just in case...
Old 06-14-2004, 08:27 PM   #19
yeah, mom was messin with my shit in the garage oh well if you guys disapprove of bosch plugs so much then maybe i'll do it in a month and try some ngk's or something.
