Old 07-30-2003, 07:25 PM   #1
G-M-W
G-M-W's Avatar
adjustable suspensions
ok i have a few questions
if i get the koni yellow adjustable shocks, i can adjust the ride height of the car right?
the next thing is which springs would be good with the yellows that would lower the car some but not have to get a camber kit
im asking this so when the winter comes around im not stuck with a car that plows the snow off the street.
i want a suspension that i can have my car sit a little lower in the summer and then back up to around the stock height for the winter
which setup would u guys recomend for me
thanks
G-M-W is offline   Reply With Quote
Old 07-30-2003, 07:29 PM   #2
ShagginJet
ShagginJet's Avatar
Re: adjustable suspensions
thanks
1. No
2. not worth lowering if you're not gonna get a camber kit, even a 1" lowering should use a camber kit.
3. a coil over set will allow you to change the ride height whenever you want.
RECENTLY UPDATED!!! 5-20-04
Old 07-30-2003, 08:14 PM   #3
G-M-W
G-M-W's Avatar
ok thanks
now if i were to stick with the koni yellows and get a camber kit....would the H&R race springs be a good choice
who has em....how much does it drop the car?
thanks again
Old 07-30-2003, 08:34 PM   #4
ShagginJet
ShagginJet's Avatar
do a search for coil* over* on ebay. The cheap ones do the job, but the higher priced ones are more worth it if you're gonna have the car for a long time.
Old 07-30-2003, 11:04 PM   #5
sohc_vtec 2NR
sohc_vtec 2NR's Avatar
koni and h & r springs are a good combo...i think pdig has 'em...
RICE....is good
Old 07-30-2003, 11:28 PM   #6
ShagginJet
ShagginJet's Avatar
^^ Don't buy from Pdig though. His prices are too low. You're noob so you should have to pay a little more... PM Pdig!!
Old 07-30-2003, 11:29 PM   #7
You don't need a camber kit for a 1" lower at ALL...
you only need one (depending on your specific susp. set up now) when you go under 2".
Old 07-30-2003, 11:49 PM   #8
The camber kit just depends on your setup and car. Get the car lowered, get an alignment, and you'll see if you need the kit or not.
Old 07-31-2003, 01:10 PM   #9
H&R are some badass sh1t! You'll like it! As mentioned, struts/shocks does not lower your ride. It's a damper. The Koni yellows are adjustable on firmness NOT ride height. Spring height will lower your ride. If you decide not to get an H&R, get a Ground Control which uses Eibach spring. Nice ride, not too bouncy...
Old 07-31-2003, 02:50 PM   #10
Re: Re: adjustable suspensions
Originally posted by ShagginJet
1. No
wrong: Koni yellows have adjustable lower spring perches. they allow lowering of the vehicle 2.5 cm for the front and 2.0 cm for the rear. but if you want more adjustability for cheaper you should look into a set of ground control coilovers. i have them for 340 shipped for the koni shocks. let me know
Old 07-31-2003, 03:12 PM   #11
Re: Re: Re: adjustable suspensions
You have to completely uninstall and reinstall the spring/strut to use a different perch though, right?
Old 07-31-2003, 09:41 PM   #12
Daym. I wish I had purchased Koni Yellows instead..... Bah, I'm happy with my set-up
Old 08-05-2003, 02:15 PM   #13
JDMB16
Re: Re: Re: Re: adjustable suspensions
Nope, I don't believe so.
I suggest GC coil overs over any except for true coil over systems like Tanabe, TEIN, Apex'i etc. And no, you won't need a camber kit unless you're hitting about 2 inches lower as stated before.
Old 08-18-2003, 01:03 AM   #14
bent_remy
bent_remy's Avatar
Yes you do. If you wanna keep your tires for a while take it from me.
Civic Dx 2 Si
Ya heard!
Old 08-18-2003, 10:21 PM   #15
JDMB16
No, you don't. If you want to waste money, take it from him. If this has happened to you, I believe you didn't get a front end alignment when you lowered your vehicle. I have my car lowered about 2 and 1/2 inches and it doesn't camber in that bad.
Old 08-18-2003, 11:40 PM   #16
No you do not. Just go to an alignment shop and have an alignment done. You only need a camber kit if they can't adjust it back to factory specs.
Old 08-22-2003, 10:05 PM   #17
Shaved &/or Laid
Shaved &/or Laid's Avatar
you could drive on your rotors
Doody Ej1
Yse.
