#1 |
6th Gear
Spoiler Installation
I'm about to install my spoiler and in the instructions it said to put some adhesive between the metal and the spoiler with the 3m double-sided tape. I threw the instructions away and I forgot the name of the adhesive I’m supposed to use. Please let me know what it’s called and if I can take the spoiler off after using that adhesive. .
Thanx ![]()
SHIFT_MyNuts Some people call it an obsession I just call it my maxima 1997 Maxima SE 5spd, Stillen Body Kit, Warpspeed Y & B pipes, Magnaflow Muffler, Koni Yellows & Tein S-tech springs, JVC Headunit, Directed 7" in dash screen,Stillen Intake, red/clear tail lights, AE mod, Paceseter STS, EL-Glow Gauges, Clutchmasters FX300 Clutch, rebuilt tranny, 19" Mille Miglia Evo 5's with Pirelli Pzero's(summer), 18" Hp D-10 hyper silver wrapped in Goodyear ultra HPR, SPW front strut bar, Helios 7000k HID, Motostorm UDP, Viper 5000Vx alarm, 2 12" PowerClass 124 subs, Kenwood 1200 Watt amp, DVD Changer |
#2 |
3M Probably.
#3 |
Yeah, 3M is the brand.
1994 Accord EX coupe --Need hosting for your pics on HST? PM me...-- |
#4 |
6th Gear
so it would be some 3m adhesive but i dunno what the adhesive is called or would it just be the thicker 3m tape that came with the spoiler.
#5 |
Tape is adhesive, so maybe so....
Aren't you Stefan's bro? He could probably help you out...
#6 |
6th Gear
yeah but he doesn't know what the adhesive is called otherwise he would of probably replied like he always does
#7 |
you have that adhesive tape. didn't you stick it to the spoiler and made the custom holes for it ? that's the one you were supposed to have there. and yes you can take the spoiler off.
#8 |
tsk tsk tsk shouldent have thrown the instructions away
#9 |
6th Gear
no shit hondamaniac i know but a96710 told me that there was supposed to be some adhesive that comes separate which seals the wholes for rust and leeks in the trunk.
#10 |
6th Gear
sorry bout the spelling *holes, leaks
#11 |
you can use a single sided foam sticker to stop leaks and then use screws to secure it and the to go that extra step, put silicone sealant on the inside of the trunk where the holes were drilled (this can be done under the spoiler too, if you want to do that)
#12 |
6th Gear
that is what i actually did but somebody told me that i was supposed to use some adhesive and it said the same in the instructions but now i remember it said something to prevent leaks if i don't use the single sided foam. So i should be fine. Thanks though
Thread Tools | |
Display Modes | |
