Old 04-14-2003, 08:02 PM   #1
rody084
cross-drilled or slotted?
hi,
I have a 1990 Integra GS and I am going to buy some AEM brake pads and I think i might need new front rotors.
I am thinking of getting some Brembo rotors because I have heard good things about them.
Should I get the Cross Drilled or the Slotted Brembo rotors? I am not going to be doing much racing, just the ocassional bit and maybe the ocasional driving down the mountains.
Which ones should I get? also, will these fit well in my 1990 Integra GS?
also, if anyone thinks I should get other company pads or rotors to work together better, please let me know, but they must be in the same price range as the ones I listed. I found the AEM pads for $44 and the Brembo rotors for $166.
thanx in advanced for your help,
Old 04-14-2003, 08:09 PM   #2
well i'd go just slotted. the crossdrilled are harder on the pads.
Old 04-15-2003, 12:28 PM   #3
autocrossthugg
autocrossthugg's Avatar
Slotted with some upgraded pads should do the trick.
Ground Control Coil-overs
Eibach springs
SPC Camber Kits (f&r)
Front Upper Strut Bar
Rear Lower Bar
3-point Sparco Harness
Old 04-15-2003, 01:19 PM   #4
I see nothing wrong with the stockers other then maybe "the look" :o
Old 04-19-2003, 02:34 AM   #5
HndaTch627
slotted, cross drilled rotors will stress fracture because 99% of those sold are not cast drilled, they are drilled on a machine.
jeremy
