Old 02-04-2003, 01:42 PM   #1
krz2fer
krz2fer's Avatar
Best way to clean engine?
I'm going to be installing an AEM intake this week... in light of this I figured it'd be as good of a time as any to clean out the engine. Since it's a 92 I'm doubting it was done before... and I sure haven't done it. Nothing is rusted out of anything, just a lot of dirt, dust and some grease.
What's the best way to make things look 'as new' as possible? What needs to be covered up when water is present? Anyone know of a website or something with details?
Thanks.
krz2fer
Old 02-04-2003, 02:02 PM   #2
Cover up the distributor, air filter (well, yours will be off, so cover the TB) fuse boxes, etc. (all electronics) before spraying it. I also heard that you should try to stay clear of the alternator for the most part.
Get some engine degreaser and follow the instructions on the bottle. I think I used "Gunk" on my old truck, but I've never done my car.
Old 02-04-2003, 04:27 PM   #3
yeah.. i cover up the plugs, distributor, alternator, and fuse box. then i spray it down with heavy duty degreaser, ise a pressure cleaner on the block, and a hose on the valve cover and intake manifold. then i put degreaser on a rag and hand detail the alternator/distrobutor. then i whip the alumnium polish out and rub down the ps pump and alternator and valve cover letters
Old 02-04-2003, 06:07 PM   #4
ShagginJet
ShagginJet's Avatar
I just used a several rags and some degreaser. Last time i used water i messed things up good. Had to have the distributor rebuilt...
Just get a hand dull of rags and some degreaser, spray the spray on the grease, wait 5 mins, come back and clean up.
RECENTLY UPDATED!!! 5-20-04
Old 02-04-2003, 06:57 PM   #5
sohc_vtec 2NR
sohc_vtec 2NR's Avatar
is it true that you should have the car runnin' when sprayin' the engine with some form of a liquid cleaner?
RICE....is good
Old 02-04-2003, 07:51 PM   #6
ShagginJet
ShagginJet's Avatar
Doesn't sound right to me....
Old 02-04-2003, 08:00 PM   #7
why so u could crack it when you spray the cold water over it ?
Old 02-05-2003, 12:54 AM   #8
Daviso27
3rd Gear
Daviso27's Avatar
Cover up all of the electronics, plugs, air filter, dist. cap, etc. You don't need the car running when you spray the cleaner...actually it is best if your engine is cold or slightly warm when you clean it..do not attempt to clean it engine is hot...it could leave streaks and sh!t everywhere.
After you spray the cleaner or degreaser, start the car and keep it running while you rinse of the cleaner with a high pressure hose. The reason for this is just incase you do get any electrical device wet...it would dry out while the engine is on...keep engine running until the majority of the engine dries...
Daviso27 is offline   Reply With Quote
Old 02-05-2003, 07:47 AM   #9
krz2fer
krz2fer's Avatar
I was actually doing to try to do the spray on rags technique. I'll attempt that moethod first.
krz2fer
Old 02-05-2003, 08:11 AM   #10
I just use a garden hose and some Simple Green. Wet the engine down, spray on the Simple Green, and scrub lightly with a brush. Then rinse it with lightly flowing water. Start it up and let it dry out a bit.
Obviously you don't want to drown your electrics, but a lil water shouldn't kill them.
Engine Before (when I first got it)
Engine After
You can't beat Simple Green. Get the spray liquid, not the foam.
Old 02-05-2003, 08:51 AM   #11
mt.biker
dam i just spray away, and so far i haven't had any problems.. am i heading for trouble?
Old 02-05-2003, 08:53 AM   #12
TonitrusEN
TonitrusEN's Avatar
yea, your engine is going to explode and your head is going to light on fire...
sorry ive been at work all night
My Baby
Unbelievable...
Old 02-05-2003, 09:30 AM   #13
juvenile
Hmmm...I really want to clean my engine as well. Nice advice you people got here! Thanks.
Old 02-05-2003, 11:25 AM   #14
krz2fer
krz2fer's Avatar
No kidding, I'm amazed at this response and actually excited to cleanr the engine out. Thanks ALOT for the pics... let's me know what I have to look forward to.
krz2fer
Old 02-05-2003, 11:32 AM   #15
thats after a decent clean... no polish involved.
Old 02-05-2003, 11:47 AM   #16
firstgeardude
i just spray away with a pressure washer when the engine is cold.... start it up ..and drive off.. no problems
Old 02-05-2003, 07:47 PM   #17
here is my engine washed in the fall. and i have a bead leak at the valve cover gasket so please excuse the mess.
