Old 12-02-2002, 02:34 PM   #1
solanog
Rear Defroster won't go off
In my 1990 LX Accord I can't turn off the rear defroster. The problem was that it would't come on until you click the switch several times. Now it won't turn off, if the ignition is not on it is off but as soon as you turn the key the defroster goes on. The switch is O.K, I borrow a new one and tried it out and nothing happened. The only way I can turn it off is disconnecting one of the lines (did with the left one) but if you need it you have to go to the back seat and connect it again. Any suggestions on what should be checked?
Old 12-02-2002, 02:36 PM   #2
make sure you wired the switch correctly. no shorts and what not. sounds like a wiring problem near the switch.
Old 12-02-2002, 02:39 PM   #3
sounds like the wireing behind the dash made a poo poo.
