Old 11-22-2002, 06:38 PM   #1
420clubbingcom
For all the 420clubbing.com haters
all right its aparent that you guys arent real racers, because if you were you wouldent brag about your body kit. Iv got a 93 accord with a crane power max cam, rollinrockers, rockerarms rollin lifters,push roods valves and springs. with an unorthodox cam gear to gear drive. it also has a bbk pully set.
Arias pistonsand connecting rods.
Meziere high flow electric water pump.
black magic electric fans.
it has a msd ditributor,cap rotor booster coil H.E.I module and super conductor wires.
ive also got a M.S.D high volumefuel pump, fuel pump booster.a NOS fogger intake manifold with dual stage progressive nitrous controler.
For exhaust i went with hooker shorty headersand borlla mufflers.it has a k&n cold air intake with an AEM bypass valve. amoroso high volume oil pump and deep valley pan.
My tranny has a Ram flywheel and clutch.
Auto meter gauges& tach recaro seeats energy suspension
bushings and mounts. neuspeedupper&lower strut bars team Loco 16in. wheelswith yokohamak6689 tires.brembo drilled& vented rotors and wildwood calipers.
WHAT YOU WANA RACE??
