Old 11-21-2002, 04:15 PM   #1
joey m
91 accord dont start
i gt into an accident with the left front of my car the left light got smashed in so it pushed the radiator back alil bit and ever since then the car wont start i have no clue wats wrong and neithor does any body i asked if u hav ne idea tell me please
Old 11-23-2002, 05:55 AM   #2
darkdaedra
Well, that's kind of a vague question, but I'll do my best to answer.
If you turn the key and hear nothing, I guarantee you that something is wrong with the wiring to or the wiring of the starter or starter solenoid. Check the wires from the firewall leading from the ignition to the starter. Make sure the wires aren't frayed or anything. Then look at the starter, if it is obviously a little damaged, it is more than likely that. Then check the wires leading from the starter to your engine; again, if anything there is frayed you're probably just having a short.
But if you got into an accident, I definitely recommend having a professional check it out. Driving around with a faulty radiator is also not a good idea. If you don't have the money to tow it to a shop and have it looked at and nothing above works, take a bus...
Old 12-03-2002, 03:54 PM   #3
turn the key onto accessory mode. If nothing turns on, like a radio, etc. Then you have a problem with your battery and related wiring. Check the ground wire coming off of the battery, because I'm pretty sure that it bolts to the chassis very close to the radiator. It could've come loose.
Old 12-03-2002, 04:23 PM   #4
i'm not sure but i think the car has a turn off switch and turns off the fuel pump when it's in a collision.
