Old 11-18-2002, 11:33 AM   #1
krz2fer
krz2fer's Avatar
Projector bulbs soldered into place?
I installed some Jaguar Eyes on my 92 civic and when inspecting the units I noticed that the bulbs seem to be connected to the wires through a soldered connected. How am I supposed to ever change the bulb, if I say, blew a bulb or just wanted the blue-tinted HID-look bulbs?
Is it something hat has to be professionally done?
-Chris
krz2fer
Old 11-23-2002, 06:41 AM   #2
TeriyakiBroccoli
5th Gear
TeriyakiBroccoli's Avatar
I've got the same question.
Old 11-24-2002, 11:13 PM   #3
SofaKingSmooth
good luck.... you can always unsolder them and put new ones in but i dont know if that will work. it would be a challange,.... well and opertunity to excel actully..... i say just hope they dont blow.
Old 12-02-2002, 08:27 PM   #4
make em last and get/use the aux lights instead
Old 12-12-2002, 04:15 PM   #5
2000Pimpinex
Super Moderator
2000Pimpinex's Avatar
They can still be removed. It will just take some force. Solder isn't the strongest thing holding them in. Just becareful not to break anything.
2008 Mustang GT
1998 Hatchback SOLD
1985 Ford Bronco XLT 5.8 351W
w/ 33X12.5X15
Old 12-19-2002, 02:02 PM   #6
I would definatly recomend de-soldering them over tearing them off.
all you have to do is heat up the metal the solder will melt and you either just pull off the wire or use a de-soldering bubble (or what ever those little squeez bottle suckers are called)
