Old 11-12-2002, 11:04 PM   #1
fossilfuel
96 Accord Rotors
How do you get the rotors off of a 96 Accord? Are they pressed on? I can't get them to budge.
Old 11-12-2002, 11:39 PM   #2
how far did u get ? you gotta remove the steering knuckles, then undo the 4 bolts that hold the hub. the hub should go out. if it's rusted in a hydraulic press is the answer.
Old 11-13-2002, 10:11 AM   #3
fossilfuel
I removed the nut holding the CV shaft and the four bolts that hold the hub. Do I need to pound the CV shaft out of the hub? Where are the steering knuckles? All of the other cars I've had, the rotors just pop off. This is a new one to me.
Old 11-13-2002, 11:07 AM   #4
yeah the system on your accord is a lot different. you gotta take the knuckle out of the balljoints, then there will be 4 screws holding the hub assembly, then the disk will come off.
here is the knuckle assembly:
and the front barke assembly
Old 11-14-2002, 03:29 PM   #5
juschilin77
hey hondaman-iac, where can i find those diagrams? not just those, the whole set, is there a place to buy or download?
Old 11-14-2002, 03:34 PM   #6
www.hondaautomotiveparts.com
and i got the mitchell repair manual for every honda made from 83 to 2000
Old 11-15-2002, 12:24 AM   #7
juschilin77
i searched thru and i couldnt find the manual..do you have a direct link? thanks
Old 11-15-2002, 01:03 AM   #8
actually it's a computer program. i use it for my daily fixes. wanna know more about it just pm or email me.
