Old 11-10-2002, 02:50 PM   #1
matthew17
I Have Major Power Problems. Stupid Stereo Sucking Jiuce, How can I
K I installed another Cab
i took out my 2 15s , and im running 2 12inch TITINIUM PHOENIX GOLD, off a 500.2 amp and a night time my lights dim almost all the way to off..
i installed 1 ferret and it still does it...
what do i need
more cabs
please...
i dont wanna buy a new alternator seeying to change them its a big thing...
Old 11-10-2002, 03:04 PM   #2
a96710
a96710's Avatar
You could try an Optima (spelling?) yellow top battery
Old 11-10-2002, 03:46 PM   #3
GSteg
upgrade the 3 main wires under the hood first with 0 gauge. if it doesn't work, then get a battery. sometimes the biggest problem can be fixed with the simplest and cheapest solution. stock wires are poopy anyways
Old 11-10-2002, 03:57 PM   #4
Just to help you out:
You installed a cap, which is short for capacitor, and the units are farads.
A simple explanation of a capacitor is that it is a device that stores electrical charge, making it a good source of potential energy for when your stereo needs it.
Old 11-11-2002, 06:37 PM   #5
ferret? did you connect its tail to ground and shove speaker wire up its nose? j/k
An alternator install wouldn't be that bad. you just gotta get dirty and understand the belts and how to wire it up.
just out of curiousity, what guage are you currently running?
and definatly install some ot guage wire in place of your primary wire to your amp, your amp ground, and your negative terminal ground.
Old 11-11-2002, 07:24 PM   #6
matthew17
im runninf 4 guage
ill get Pictures right away.
Old 11-13-2002, 12:30 AM   #7
thankfully your not like the idiots in my town and run 8 guage to their huge wattage amps. I heard a story once of a guy that used speaker wire...
