Old 11-07-2002, 05:52 PM   #1
bizkit18
need some advice
I had mahdavi motorsports perform a motor swap about 2 months ago. Overall I'm impressed with the work. Now comes my problem. After I left it drove great for about 200 miles. After that it started to miss, spit, sputter and sound funny. I tried different suggestions from you guys with no luck. Finally I pulled the fuel filter and found the problem. The fuel tank was covered in rust. Now I'm in the process of replacing everything in the fuel system. (tank, fuel pump, filter, fuel rail, injectors, and I had already replaced the fuel pressure regulator. My question is what products should I buy to replace all of this. And is there anything else I need to replace. Also I heard I should change my map sensor and my fuel pump to that of a 94 integra, is this correct. All of your help is greatly appreciated. Thank You.
