Old 11-05-2002, 10:08 PM   #1
TonitrusEN
TonitrusEN's Avatar
Crappy Idle?
Well last week I installed some MSD 8.5mm wires, and about a week or 2 before that i did a venom 400. For the last few weeks ive noticed my idle is really rough... like really rough..
i thought it was the venom at first but i turned it off and it still did it.. so i thought maybe it wasnt getting enough spark so i put the MSD wires in...
then i noticed that my 4th cylinder MSD wire kept coming off the plug, and it was taking a crap.. so i fixed that, well im still stuck with a rough idle... and now i noticed my tranny feels like its slipping, but i dont think it is since they told me at the trans. shop that it was fine. But like if im at a light and im going up hill.. my tranny will slip and slip and slip until i get on a flat surface, then it will downshift and go but with lack of power..
I put some fuel injector cleaner in, and filled up today cause one of the guys at a local racing shop said it might be dirty injectors, but what does it sound like to you guys?
if this doesnt make sense to you, slap me :P
Thanks in advance
jason
My Baby
Unbelievable...
Old 11-05-2002, 10:30 PM   #2
TonitrusEN
TonitrusEN's Avatar
Shameless bump
My Baby
Unbelievable...
Old 11-06-2002, 05:07 PM   #3
How rough? Like almost going to die rough, or just real low RPMs? Does it fluctuate a lot? check all your connections, check your spark plugs.
Your other problems, I have no idea, but it sounds expensive.
Old 11-07-2002, 01:45 PM   #4
it sounds to me that the wires are bad. put back on the 6.5 mm wires until you get a new coil and ignition. And might as well check the dist cap and rotor.
Old 11-07-2002, 02:33 PM   #5
TonitrusEN
TonitrusEN's Avatar
It seems like its almost going to die rough...
I dont have a tach but its fluctuating quite a bit..
Im dropping it off at a mechanic tonight since im going out of town for 4 days, i figure it couldnt hurt..
My Baby
Unbelievable...
Old 11-08-2002, 12:34 AM   #6
Same here. I tried messing with mine earlier today, but it's hopeless, and I'm way in over my head. to the mechanic it goes!
Old 11-19-2002, 10:22 PM   #7
DrumminBoy
Update us on what the mechanic says. I'm having the same problems with my '92. What is your idle speed? I usually idle around 1500 and i KNOW that cant be right...
Old 11-19-2002, 10:30 PM   #8
what ? 1500rpms ? your idle is quite screwed up. it should be half of that with the iacv connceted and 500 with it disconected
Old 11-20-2002, 01:18 AM   #9
DrumminBoy
what would be causing it?
Old 11-20-2002, 02:55 AM   #10
armyguy5
3rd Gear
armyguy5's Avatar
are all of your cylinders firing??
chris
Old 11-21-2002, 01:32 AM   #11
DrumminBoy
im assuming they are, how would i know if they werent?
Old 11-21-2002, 01:40 AM   #12
TeriyakiBroccoli
5th Gear
TeriyakiBroccoli's Avatar
mine idles at 1500 initally, then goes down to 700-800 after warming up.
Old 11-21-2002, 10:00 AM   #13
that is fine. every cold engine does that.
Old 11-21-2002, 10:01 AM   #14
you will know it because the engine seems like stalling and shaking like a mofo.
Old 11-21-2002, 10:38 AM   #15
TeriyakiBroccoli
5th Gear
I know, im just stating that
Old 11-21-2002, 02:53 PM   #16
armyguy5
3rd Gear
armyguy5's Avatar
well thers to things u can do. Buy a compresion tester or talk to a master tech at a dealer..
Old 11-21-2002, 05:20 PM   #17
DrumminBoy
Well it shakes a little bit, but nothing violent. I usually idle around 1500, but sometimes it'll get pretty low too, around maybe 300-400 and when i push the brake pedal the rpm's go way down, and it feels like im gonna kill it.
Old 11-21-2002, 05:22 PM   #18
sounds to me more like a vacuum problem. you have power brakes right ?
Old 11-21-2002, 05:26 PM   #19
DrumminBoy
yep
Old 11-21-2002, 05:29 PM   #20
have the vacuum hoses checked out, the throttle body cleaned up, and a fuel filter change. also add some fuel filter cleaner to your next fill up
