Old 10-29-2002, 03:01 PM   #1
solanog
Iddle drops too low
When I stop at a light, iddle speed drops, the engine almost stops, and then goes up and a couple of seconds later stabilizes. Any Idea what could this be. When engine is cold, idle speed is around 800 for a little while and then goes to around 1200. Is this normal? Should I check the idle speed? How do I adjust it? I think there's a screw in the throttle body for idle adjustment but does not seem to help, idle speed varies but the problem continues. Should the IACV need to be adjusted too? How?
