Closed Thread
Old 10-21-2002, 06:48 PM   #1
Dr Drew
Turbo setups...What should be used with what...
Mild Street Setup / For D-Series Engines.
Legal depending on mods to kit...
5-7 psi
Greddy kit (www.greddy.com)
Turbo timer (www.greddy.com)
Boost/A-F gauges
Stock Internals
Stock Fuel pump
Stock Injectors
B&M FPR
MSD wires w/colder stock plugs
2.5” Catback exhaust
High flow cat
Clutch Master stage III (www.clutchmaster.com)
Stock/Mild suspension upgrades
Mild Street Setup / For B-Series Engines
Prolly not very legal
7-9 psi
Revhard Stage II (www.revhard.com)
Hondata (www.Hondata.com)
Boost/A-F Gauges
Stock internals
255lph Fuel pump
440cc injectors *optional depending on boost (www.rceng.com)
MSD ignition setup
MSD wires
B&M FPR
Thermal 3” Catback (www.thermalrd.com)
Cam gears (www.venom-performance.com)
Clutch Master stage IV (www.clutchmaster.com)
Full suspension upgrades
Upgraded brakes
Sadistic Street setup / D-Series internals needed, B not required. You might have a chance if you get pulled over
9-12 psi (boost controlled)
Hondata/Accel DFI/AEM (www.hondata.com)
Profec B boost controller (www.greddy.com)
Boost/A-F/EGT gauges
JE (www.jepistons.com)
SS Ferrea (www.ferrea.com)
Stiffer dual valve springs w/titanium retainers (www.Portflow.com)
Eagle Rods
Blockguard for B-Series required
Sleeving required for D-Series (www.goldeneaglemfg.com)
255lph Fuel pump
440cc+ injectors (www.rceng.com)
MSD/Jacob Electronics ignition setup (www.jacobselectronics.com)
Magnacore wires (www.magnecor.com)
AEM fuel rail w/FPR
Oil cooler
Dual slim line cooling fans
Under drive Pulleys or loose the accessories
Big Brake Kit
Full Blown Street Racer / Track Trailer Queen
Lots of boost (you might "blow the welds on the manifold")
Revhard Stage III / Custom setup (www.revhard.com)
Hondata/Accel DFI/AEM/Haltec/Motec (www.motec.com)
Profec spec B boost controller (www.greddy.com)
STR Intake manifold
JE pistons(www.jepistons.com)
Ceramic coated pistons and combustion chamber
Resleeved block GE/Darton sleeves (www.goldeneaglemfg.com)
Crower Turbo cams (www.crower.com)
Crower Rods (www.crower.com)
Block guard
255lph Fuel pump
720cc+ injectors (www.rceng.com)
AEM fuel rail w/FPR
Oil cooler
Clutch Master stage V (www.clutchmaster.com)
LSD (www.kaazusa.com)
Chrome Moly Axles
Big Brake Kit
Roll cage (www.artmorrison.com)
I listed Revhard as the turbo system, simply because that is what I am familiar with. Some other companies are:
Drag (www.overboost.com)
Greddy (www.greddy.com)
If someone see something that doesn't seem rgt or they feel should be updated please PM me. If anyone has any questions please post in here incase anyone else has the same question.
Old 12-01-2002, 11:02 AM   #2
Deej
don't forget about FMAX! (www.f-max.com)
they have a REALLY nice turbo setup it's what i currently have now.
Closed Thread
