Old 10-12-2002, 04:49 PM   #1
BrandonClaps
Got slow windows?? Here is the HONDA Fix *pics*....
*This is ALSO in the Step By Step, but it didn't display the picture, and i must have a place where it displays the picture for a lil bit ;D*
Welp, as you all know honda civics are notorious for having slowwww windows. So I chatted with honda for a bit, and found out what needs to be done. Of course since I love you guys, I shall share with you. Of course there is pictures, otherwise it's not a good how to right? right.... Sooo here we go
Supplies:
....Silicone Spray *make sure you don't get adhesive!!!*
....Philips Screw driver
....30 minutes
1. Remove the door panel. For 96-00 civics, there are count em, 5 philips head screws. One in the window control, one in the door latch, and three behind the speaker grille. To remove the door panel, pull from the bottom out, don't pull to hard, because you must disconnect the speaker. Or you can unscrew the speaker and disconnect it that way, but since I just had my door panels off for the components, i know how it works. Once it's pulled out at the bottom, kinda slide it up and it will come out. Of course don't forget the window wire harness, and the door latch bezel. It's easier if the window is down to remove the door panel.
2. Basically the whole problem is the rubber tracks get dry and need to be lubed up good ;D :insert joke here: Raise your window up!! So get your silicone spray (make sure it has a little straw damn it, otherwise your window is gonna be covered in silicone. And your gonna wanna spray it in the tracks in the pics below. Make the window go up and down so the silicone spreads out. Don't drench it.
3. You can also spray some on on the X bracket thingy, but that should already have grease in it.
4. Put your door panels back on. Put your window down! Then spray in these spots below, don't do it full blast otherwise your window is gonna be covered. Just let it trickle down into place. Thats it, test it out and your good to go.
