Old 10-07-2002, 10:50 PM   #1
asian accord boi
need help on struts
alrite...front upper struts...when u install them...when u unscrew the bolts from your chasis....do the srpings fall out of place or what....and also will struts will make me feel a difference in my kar?....and w
htas this thing i hear about my hood mite not close??
Old 10-07-2002, 10:57 PM   #2
nope, the springs won't fall off. thw whole strut assembly will fall off, then you gotta remove the upper spring seat by unscrewing the 14mm nut on top of the whole assemble. yes springs will make a difference in your car
Old 10-08-2002, 07:22 PM   #3
SilvaAccord
the springs wont fall off. I know for mine it was a ***** to put on. That black metal piece is a ***** to pull up. You will defiantly feel the difference when you have it on your car. The chasse of the car won’t twist as much. That means harder turns.
Old 10-08-2002, 11:51 PM   #4
asian accord boi
hey silvaacord thanks a lot ....man they are a ***** to put in!!!! :o
