Old 10-07-2002, 07:56 PM   #1
CRX style
Engine Swap
Ok, so the conversion aint the best idea in the world. And I'm not so sure that the car I have is worth the money. At any rate, if y'all could give advice on engines and what kind of money I'm going to wind up spending at the least would be greatly appreaciated.
Old 10-07-2002, 10:19 PM   #2
Kyle
elyK
if you're lookin to not spend too much money go with the b16...it's pretty fast, and it usually only costs about 1500...
but if you're goin for all out speed...(like me) go with the h22(prelude engine)
I think you can get it for 2800 shipped...
well, i'm not that knowledgable about engines...so i'll let everyone else try to explain this shiz...
IGNORE THE FACTS
EXPLORE THE TRUTH
Old 10-07-2002, 10:45 PM   #3
whats your maximum price limit, and we'll tell you what you can get. a h22 isnt a feasable crx swap and have it as a daily driver. a b18c1 will probobly be your best bet
Old 10-07-2002, 11:22 PM   #4
Violent Apathy
Violent Apathy's Avatar
B18C1!!!
Black 2007 Mustang GT California Special
"There he goes. One of God's own prototypes. Some kind of high powered mutant never even considered for mass production. Too weird to live, and too rare to die." - Hunter S. Thompson, 1937-2005
Violent Apathy is offline   Reply With Quote
Old 10-08-2002, 12:32 AM   #5
CRX style
Money?
As far as money goes I think I would be willing to spend in the range of $3000 for something that would whip these little wannabe Honda's running around here. I'm not all that knowledgeablly in the swapping engines area of cars though. If I can do the whole deal for 3 grand, computer and all, I would be a heppy camper.
Old 10-08-2002, 12:41 AM   #6
ZC might be your only feasable swap, maybe a first gen b16.
Old 10-08-2002, 02:14 PM   #7
I know a guy that has a ZC swap in his CRX and he runs 15.8 at the track...Very shitty track I might add also. I say b16 or ZC. They are both affordiable and fit in nicely into the engine bay.
Old 10-08-2002, 03:14 PM   #8
crxb16hybrid
Do the b16 its your best bet. I run a b16 in mine and its fast enough for me . The install is real simple to if you got the time it will save you alot of cash.
Old 10-09-2002, 02:04 AM   #9
CRX style
Compression ratios?
I'm wanted to turbocharge the engine I put in the car. I have a friend that says that a lower compression would be a wise idea if I go that route. Will a b16 do well with a turbo charger?
Old 10-09-2002, 02:09 AM   #10
Re: Compression ratios?
Yeah it does good with a turbo. Just don't boost over 6 psi (from what i'm told.)
Old 10-09-2002, 09:31 AM   #11
crxb16hybrid
6 psi is the way to go if your wanting to bolt it on an go .... But you can go alot higher if your willing to put in some extra cash to replace some internal parts....If your looking for a great bolt on kit I would recomend F-max....They make a complete turbo kit for 88-91 crxs with b16a transplants ........ It has everything you need including an exhaust manifold , intercoller , downpipe with 2 o2 sensors , boost tube , modified compressor housing , intake tube , T3/T04B turbo , 2 10 inch perma cool electric fans , 35mm TiAL wastegate , wastegate dumptube , HKS standard racing bypass valve , K&N bypass valve filter , K&N filter and a turbo oil line.....Hope this helps you out some ....In my honest opinion your alot better off swaping to a b16 instead of the zc.......Good luck
Ty
Lucky13
Old 10-10-2002, 03:38 AM   #12
Originally posted by crxb16hybrid
T3/T04B turbo Lucky13
I don't know much about turbo's but i was told that's a pretty big turbo for a b16
Old 10-10-2002, 10:14 AM   #13
diligent_dave
That's not that large, especially since the b16 revs so high. It's got the smaller t3 turbine which makes it easier to spin but with the larger t4 compressor.
A good friend of one of my buddies has a crv motor in either a crx or a hatch, I don't remember right now. But he did it all himself and the thing drives. Yeah that's right. I said crv.
Old 10-10-2002, 10:38 AM   #14
crxb16hybrid
It is a good enough turbo to run if your not wanting to spend alot of cash on reworking the internals....
Old 10-10-2002, 10:44 AM   #15
if you wana turbo, a ZC or a b20 might be a cheaper way to go. and get good power
Old 10-10-2002, 10:49 AM   #16
crxb16hybrid
ohhhhhh I thought they were talkin about turboing a b16....B dubs are a nice way to go as long as they are built properly.
From what i understand if your gonna go with the b dub you want the b20z....
Old 01-20-2021, 03:26 AM   #17
fertooos
I am looking for a bookie platform with the lowest commissions. Can you suggest some decent sites? At the moment, I am betting at new sports betting sites australia https://online-bookmakers.com/en/aus...betting-sites/. Do you think European sites can be cheaper? I have to make some more research to understand more and avoid hidden payments.
fertooos is offline   Reply With Quote
Old 02-10-2021, 07:45 AM   #18
Hopkins
Chevrolet Small-Block
Atmospheric or compressed V8, lower-shaft, 5.7-7.0 litre displacement
Advantages: high displacement, good boost potential, plenty of tuning parts
The slang name "Small Block" is used to describe several families of V8 engines with cast iron or aluminum body, which were and are still being installed on General Motors full-size pickups, SUVs and sportcars - Chevrolet Silverado, Chevrolet Tahoe, Chevrolet Corvette, and others. For its half-century history, they have reached almost perfection: top versions develop 500-600 horsepower even from assembly line. These engines are produced in millions of copies, and for swap you don't need to look for a donor: GM Performance Parts Department offers motors separately - especially for motorsport and tuning.
These engines are installed everywhere in the U.S.: in SUVs and European sedans, small roadsters and crazy drag racing bolides. Professional drifters have figured them out: American motors are used in Nissan Silvia and Skyline, BMW of the third series and Toyota Supra. Sideways specialists are attracted by high power, breakneck thrust and perfect throttle response together with excellent reliability - it's almost impossible to get all that from low-volume Japanese turbocharged engines at once.
Hello all car enthusiasts, spoil yourself not only with car parts but also with emotions in the online casino no deposit bonus codes
Hopkins is offline   Reply With Quote
Old 04-07-2021, 11:37 PM   #19
zackwang
Thanks for your sharing,That's pretty cool.
SEO
zackwang is offline   Reply With Quote
Old 05-20-2021, 09:53 AM   #20
Nooret
Nooret's Avatar
Originally Posted by fertooos
I am looking for a bookie platform with the lowest commissions. Can you suggest some decent sites? At the moment, I am betting at new sports betting sites australia Do you think European sites can be cheaper? I have to make some more research to understand more and avoid hidden payments.
i love this site too and didn't find another yet
Nooret is offline   Reply With Quote
Old 05-20-2021, 09:56 AM   #21
Johanson7
Johanson7's Avatar
Thank you! Its usefull
Johanson7 is offline   Reply With Quote
