Go Back   HSTuners > Tech Talk > High Performance > Supercharger
Old 09-30-2002, 03:22 PM   #1
ForceInjection
Post ROOTS Style supercharger
History
The roots style supercharger is the oldest type of supercharger and dates back to the early 1900's when it was first used as an industrial air-moving device. In the past 30 years or so, however, the roots style supercharger has undergone drastic changes and has become so efficient and quiet that it is now commonly used as a forced induction system for automotive applications. The roots style supercharger, while still the least thermally efficient supercharger design (versus centrifugal and screw-type designs), has found a home on board top fuel dragsters as well as on modern Mercedes, Ford, and GM passenger cars as an original equipment power adder.
How it Works
The roots type supercharger is two counter-rotating meshed lobed rotors. The two rotors trap air in the gaps between rotors and push it against the compressor housing as they rotate towards the outlet/discharge port. During each rotation, a specific fixed amount of air is trapped and moved to the outlet port where it is compressed, which is why the roots type supercharger falls under the broader catogory of fixed-displacement superchargers (like the twin screw supercharger).
Advantages & Disadvantages
The roots type supercharger is known for its ability to produce large amounts of boost while spinning at very low speeds. On an automotive application, a roots type supercharger can often make it's full (peak) boost by 2000 engine rpm. This characteristic has contributed to its success and popularity on the top fuel racing circuit and has made it ideal for use on smaller 4 and 6 cylinder engines that traditionally struggle in the lower half of the rpm range (and is why Jackson Racing uses a roots type Eaton compressor). Another advantageous characteristic of the roots type supercharger is its simplicity of design. The roots type supercharger has very few moving parts and spins at low rpms, making it one of the more reliable and durable aupercharger designs.
The big disadvantage to the roots type supercharger is its thermal inefficiency - or its nature to produce high discharge temperatures - which robs power from the engine. With a roots type supercharger, an intercooler is almost always a necessity to bring the air charge temperatures down to an acceptable level. This poor thermal efficiency can be attributed to the fact that it has no internal compression (compression is done after the air leaves the discharge port). Additional heat is created by compressed (hot) air that leaks backwards past the rotors and heats up the temperature of the inlet charge.
