Old 09-28-2002, 03:19 PM   #1
Nasty rattle at 50mph+
Ok this is driving me nuts...
When I'm going at 50 mph or over, and then take my foot off the accel, I get a nasty thump thump thump thump.... What could this be? I'm thinking clutch or brake rotors. The clutch is starting to go out, and it slips terribly. I had it up on jacks a while ago and it was it neutral. When I revved it a bit the wheel started turning. Could the rattle be the clutch slipping?
I'm going to try a test, I'll go 50-60 then put the clutch in and see what the noise does.
Old 09-28-2002, 04:41 PM   #2
juvenile
I actually have EXACTLY the same problem
I mean word for word you named it
50mph I begin to feel it...around 60-75 it gets somewhat worse!
And only when I take my foot of the accel
my dad thinks it's the engine mount pads!
Old 09-28-2002, 04:48 PM   #3
isn't that weird? engine mount pads....hmm...I wouldn't know how to check those....
Just so I can eliminate e few things on my end, what condition are your brakes in? How new is your clutch, or is your chronos a stick?
Old 09-28-2002, 04:55 PM   #4
juvenile
stick
just got it with safety done so brakes are all new
and the rotors up front are new also
clutch not sure but it grips pretty early on the way out!
and yes it is definitaly weird and annoying!
Old 09-28-2002, 05:55 PM   #5
i'd check motor mounts... maybe balencing your tires..
Old 09-28-2002, 10:17 PM   #6
juvenile
It's not tire balancing because my steering wheel doesn't shake!
On my Concorde, the wheel shock at 130kmh
~80mph I think...so that was balacing...I'm pretty sure this isnt'!
Old 09-29-2002, 01:26 AM   #7
Check your mounts. If you put it in gear then let off the clutch your engine shouldn't move a whole lot. There will be some play, but if it looks like its "slamming" around you probably have issues.
Old 09-29-2002, 02:20 AM   #8
juvenile
No no it happens say I'm in 4th or 5th and doing 50mph+
then I just let off the gas pedal...then it starts doing it
not when I'm shifting!
Old 09-29-2002, 02:51 AM   #9
bad tires.
Old 09-29-2002, 02:54 AM   #10
juvenile
My fronts are new tires! Brand new...rears are a bit old.
and I can actuall feel it coming fromt he engine bay...not the suspension/tires part of the car!
Old 09-29-2002, 02:59 AM   #11
have them rebalanced and look for bends in the rim. also check the crossmembers.
Old 09-29-2002, 10:57 AM   #12
juvenile
wouldn't the steering wheel shake if they aren't balanced? because mine is normal...doesn't shake at all.
Old 09-29-2002, 02:11 PM   #13
What do you mean by crossmembers?
the shaking couldn't be cv joints could it? I had a torn one for a while, fixed it, but maybe the damage was already done?
Old 10-13-2002, 03:37 PM   #14
ah boy do I feel stupid. I figured out what my rattle was, but first a story...
I was wd-40 ing some rust on my car and had to take the wheels off to do it. I took care of it and put the wheels back on. The next day as I'm driving to school a hear the nasty rattle again, but its happening at low speeds also (25-30). As I'm driving home from school it is getting extremely bad, and I'm getting increasingly worried. I stop of at my cousins house to get it in the air so I can take a look, and then I have an idea. I whip out the tire iron and guess what? the lugs were loose as bastards. I felt so incredibly stupid! I could've lost my wheel! I always tighten the lugs when I'm done, but I must've been distracted or something. That was also probably the problem before, just didn't tighten them enough. So...
ALWAYS TRIPLE CHECK YOUR LUG NUTS BEFORE DRIVING!!!!
Old 10-13-2002, 06:59 PM   #15
Damn. That could've been bad....
Old 10-14-2002, 03:28 PM   #16
Yes...extremely bad. juvenile, make sure you check your lugnuts!!!
