Old 09-24-2002, 06:51 PM   #1
Asia101
18" or 17" and how low can you go...
2000 3.0L EX Coupe:
I want to drop the car and add 18" to them. A friend said that he thought 18" would rub underneath. I am curious to know if this is true. Also, the car has a smooth ride now, how low can I go without jeopardizing the ride too much, since I will have 17" or 18" the ride will be less comfortable already, correct?
Basically, I want the car to look smooth but drive smooth also...I don't plan on racing it or doing anything crazy with my baby...
Thanks for the input...
Old 09-24-2002, 07:01 PM   #2
You can fit 18s on a 6th gen with no problems. Get the correct offset. The ride will be slightly bumpier due to less tire cushioning, but you'll be fine.
You could drop 1.5-2" and have no problems. Ride stiffness depends on the products you get.
Old 09-24-2002, 07:11 PM   #3
Asia101
What size tires should I go with if I choose the 18"s and what products for dropping the car 1.5" for the smoothest ride (as in comfort and not too bumpy)? In other words, I want smooth ride over performance since I don't plan to race her...just take the ladies out in my baby...
94 Accord EX recommended Eibach pro-kit springs with Koni yellow struts...any other suggestions?
This is my first Honda and modification.
Old 09-24-2002, 07:35 PM   #4
I recommended that before I knew you just wanted comfort, and now I'll re-recommend the pro-kit/koni combo. You'll pay around $550 for the Koni yellows, but it should be well worth it. They have 5 way damping adjustment from stiff to fairly soft. If you'd like to save some money, KYB AGX struts will work for that drop. Theoretically, stock struts would work for a while with that little of a drop, but I wouldn't recommend it.
Old 09-24-2002, 07:42 PM   #5
Asia101
I pretty much want the best product money can buy...as stated before, I prefer comfort over performance because I am not racing. With that said, do you still recommend Koni yellows and pro-kit combo? Where can I find the best prices for this combo?
Thanks for any inputs...
Old 09-24-2002, 07:50 PM   #6
For comfort, I do still recommend these. Best money could buy in my eyes is purely performance related, but your ride quality would suffer greatly. I'd wait for some other opinions though.
You can check www.groupbuycenter.com for good prices. Also, there are two versions... one has the front two struts externally adjustable only, and the other version (~$40 more) has all four adjustable. You want to be able to adjust all four externally.
Shox.com also has great prices. When I was looking at them, they had the yellows for ~$540 and I think around $190 for the pro-kits.
Old 09-24-2002, 10:47 PM   #7
trev there are no AGX's for the 6th gen accord. i haven't seen them yet.
also i would say go with the prokit/koni yellow combo
Old 09-24-2002, 11:20 PM   #8
Damn, I always forget about that
Old 09-25-2002, 12:26 AM   #9
Rob
Stefan's A Sheep Fucker
Rob's Avatar
I have Eibach ERS springs with Ground Control coil adjustment and Koni shocks and my ride is pretty damn comfortable for it being lowered...oh and I have 18's on 225/40/18's.........
Old 09-25-2002, 01:47 AM   #10
azn_nite_ryder
you can drop 3.5" no prob without rub on 18's....
tire size you can go is 215/35/18 even a 40 series youd be fine in...
as for shocks... the best by far (and i have it in my car too) are the GAB 8 way adjustables...... they are (IMO) better then konis or tokico....
Old 09-25-2002, 12:15 PM   #11
spoogenet
What offset and what wheel width are you running? 7.5" with +45mm?
b
Old 09-25-2002, 02:32 PM   #12
Asia101
Do these provide a comfortable ride? 3.5" is pretty low, most of the peeps are recommending between 1.5"- 2.0"...
Also, what about dings in the wheel? The last thing that I need is to put a huge dent in the wheels...
Old 09-25-2002, 07:07 PM   #13
Rob
Rob's Avatar
Old 09-25-2002, 09:00 PM   #14
azn_nite_ryder
oops my bad.. i didnt read that part... well a 2.5" you'll be fine... just make sure you have a good setup of struts under there wher eyou can adjust the ride.. the wells of our accords are very huge so a 1.5-2" drop will sitlll kinda look high.. 2.5 you should be fine without sacrificing the ride...
Old 09-26-2002, 01:56 AM   #15
Asia101
The lower I go, doesnt that effect the comfort level of my ride?
What do you guys think of the Eibach Sportline Lowering Springs - 2dr 6cyl EX - Front Lowering 2.0" - Rear Lowering 2.0"
Or the Skunk 2 Lowering Springs - 6 Cyl - Lowers Front and Rear 2.25-2.5"
Also, I heard that if I use Koni Yellows, it will drop the ride just a tad bit more too...is that correct?
Let me know your thoughts...
Old 09-26-2002, 02:03 AM   #16
If you want to go as low as sportlines (possibly settle to 2.1-2.2"), those are great springs also. Be advised that you'll need a camber kit if you go that low though.
Old 09-26-2002, 02:09 AM   #17
Rob
Rob's Avatar
I would go with Eibach...just personal preference.......
Old 09-26-2002, 04:39 PM   #18
Asia101
are camber kits all pretty much the same thing or is there a difference?
