Old 09-20-2002, 01:16 PM   #1
kilo97civic
aftermarket fuel rail
would an aftermarket fuel rail...like aem or venom give me more flow withour changing the stock injectors??
Old 09-20-2002, 02:38 PM   #2
usually yes, but what mods have you done to the car ? i know some of those have the N<sub>2</sub>O port in them
Old 09-21-2002, 01:12 AM   #3
If you want more flow without changing injectors just get an adjustable FPR and increase the fuel pressure.
Old 09-21-2002, 01:59 AM   #4
delsolvtec
Del Sol Forum Moderator
delsolvtec's Avatar
Yes, if you add a fuel rail and a fuel pressure regulator you will get more flow through the stock injectors. A fuel rail alone will give smoother flow, but without a fuel pressure riser it won't flow anymore the before. Spend the extra 50-60$ to get a B&M fuel flow modifier. Also think about adding a fuel pump. I picked up a BBK fuel pump capable of supporting 500hp for around 200$ from optionsautosalon.com
1994 Mazda MX6 - For Sale
Old 09-21-2002, 02:03 AM   #5
VieT916
Re: aftermarket fuel rail
it's not necessary unless you're pumping out maaaaaaaaad horsepower/torque. The OEM one flows more than enough fuel; the injectors and fuel pump are usually the culprit to a lack of fuel delivery. Only buy one if you want to win points for your engine bay. hell, why do you think many Hondacura guys with boost still use the stock fuel rail when pushing over 12 psi into their cylinders? because the stock one is perfectly fine.
Old 09-21-2002, 11:36 PM   #6
'00EX5-turbo
viet
u are right, man!
i used to have both the aem fuel rail and aem fuel pressure regulator on. but then later i took the aem FPR off becuz the mechanic said it was not necessary for my car(turbo setup, the fuel unit that came with the kit and the bbk fuel pump were already good enough). so i m using the stock one now.
Old 09-21-2002, 11:56 PM   #7
Re: viet
Originally posted by '00EX5-turbo
u are right, man!
So are you saying you're using the stock FPR? Or the stock fuel rail?
Old 09-22-2002, 04:44 PM   #8
'00EX5-turbo
i m using the stock FPR and the aem fuel rail.
Old 09-22-2002, 08:05 PM   #9
So you have an upgraded fuel pump and a stock FPR set at the stock setting?
