Old 09-04-2002, 10:54 PM   #1
96civicFL
B18 or H22
I got a 96 civic some pple say B18 and some say H22 cause the H22 is heavyer
The H22 gets 197 hp and i dont know what the B18 gets plz comfirm this with me
and what would you all get thanks
And for the H22 how much would it cost to get every thing i need (Estamate) and the same for The B18
Old 09-04-2002, 11:39 PM   #2
the h22 will be better by far, even thou it will cost more to have it put in, but think about the torque it produces. b18's are anywhere from 140 hp to 170 hp depending on the head version.
Old 09-04-2002, 11:49 PM   #3
96civicFL
ok i got the specs
H22 and 5speed and GSR header and mounts
2300 + 600+ 300=$3200
197hp/162tq
^80lb heavyer
B18 and 5 speed and Header
2950+300=$3250
170hp/126tq uses same mounts
the H22 will be alittle more to put in if i dont do it my self (i dont have the time and realy the no how to do it so )
Old 09-05-2002, 01:05 AM   #4
ShEaNy
ShEaNy's Avatar
hey get a B18C6/7 type R engine..200 - 220 hp...
Old 09-05-2002, 05:39 AM   #5
there's a whole bunch of other stuff you need when doing a swap especially with the h22. To do the h22 swap right it'll cost somewhere about $5000 of you do the work yourself then you can add labor if someone else does it.
Its just a little cheaper to go with the GSR engine. About 800$ cheaper.
Old 09-05-2002, 11:04 AM   #6
96civicFL
I am looking at spending upwards of 10 grand at first to get this project going I curently am wanting to do a swap on my 96 ex but am looking at trading a friend for his 94 ex so first i have to figure out what i want to do with that and when i figure it out to do the swap
and the 10k is just for motor work ONLY!! and looking for a reliable 350whp street car and a 450+ drag car
cause this will be my dayly driver but i also have a few othere cars i can drive if this so happens to go on me
So i want a high hp motor but I also want it to be the most reliable for those hp ratings
i am wanting to do turbo/intercooler and alot of ppl are telling me to stay away from the juice so thats what i have to work with and thanks for your imputs guys
Old 09-05-2002, 11:31 AM   #7
kickuaround
b18c = autoX
h22= Draq
h22 is harder to do. it'll cost you. b18c is the way to go man. you don't need a type r. it's a waste of money. check out my buddies site. whatever you get, get it from him. jdmclub.com
he's in tampa, fl.
Old 09-05-2002, 11:08 PM   #8
96civicFL
humm yea i know not to get the type R gain a few ponies for a large amout of $$ humm and tampa i am daytona and i got family in tampa I will check the site out thanks guys anymore/all suggestions are welcome i got a 10k budget on motor only but would like to take that else were on the car if i dont use it so i want the most bang for buck but i alsot want high 12's atlest (on the track)
Old 09-06-2002, 01:56 AM   #9
With 10k$ you should be in the 11's.
Old 09-10-2002, 04:50 AM   #10
ricerX
Tell me how you would go about that. I'm assuming engine swap + rebuild for turbo / sc + boost = 11s... Is that where you were going with that thought? Let me know! Thanks!
Old 09-10-2002, 06:35 AM   #11
Yes, if you took a h22 did a little rebuilding so it could handle good boost and then slapped a turbo on it, you could easily make 400hp. Add slicks and axles that won't break then you should be in the 11's. Or take that same built h22 and save some money and get a decent nitrous set up and do it that way.
