Old 09-04-2002, 04:39 AM   #1
fadednite
Best spark plugs for civics
I have a 97 civic EX. How makes the best spark plugs and what material is better? I hear alot of platinum and the new iridiums. What do you guys think?
Old 09-04-2002, 09:52 AM   #2
Whtehnda93DXSdn
It has 4 Doors...
Whtehnda93DXSdn's Avatar
well to be honest I would say go w/ NGK V-power for your honda. I wouldn't suggest iridium plugs unless you run like NOS or something.
Just my $.02 hope it might help a bit...
Another good forum site:
Tuners Alliance
Old 09-04-2002, 10:33 AM   #3
Originally posted by Whtehnda93DXSdn
well to be honest I would say go w/ NGK V-power for your honda...
Ditto
Old 09-04-2002, 11:00 AM   #4
i have the v-powers, but they make the car hesiate after a while.
Old 09-05-2002, 12:20 PM   #5
fadednite
! what do you mean hesitate? btw how much do they cost?
Old 09-05-2002, 03:47 PM   #6
V-Powers came in my car stock, Ive put 3 different sets in the and have never had a problem. I think its just your car.
You can usually find them for about 8-10$ for a set of 4 depending on the place you buy them.
Old 09-05-2002, 04:28 PM   #7
Spark plugs have been around for over 100 years and they haven't changed a lot. They spark, they erode, they die. The trick is to replace them somewhere between 'erode' and 'die' phase.
All the improvements, so called, have been to the electrode TIP. Nothing has been done to the ground. So, what we have now are spark plugs with wonderful 'new millenium' tips that last forever and sh!tty grounds that erode just like they did in 1920.
What's the best? Generally speaking, for most ppl, that would be the 'tried and true' copper-core spark plug, i.e. the NGK V-Powers mentioned above. They work great, they're cheap, but they don't last very long. The hot setup, if you'll pardon the pun, is to replace them every 15-20k. That'll put you right in the middle of that erode/fail cycle I was talking about.
The absolute best, of course, are silver-core plugs. But, they're expensive, hard to find, and don't come in as many different flavors as copper-core plugs.
As far as which plugs are the most efficient:
Once again, silver-core is the best, but copper-core is a close second.
One thing to mention here is the thermal conductivity thing. One of the most important features of a spark plug is its ability to carry heat away from the combustion chamber. THIS IS MUY IMPORTANTE! And, that's the primary reason you are supposed to use a torque wrench when you install plugs; to allow proper heat transfer. I don't want to put you to sleep, so we won't go any further into this other than to say, look at the chart and you will see copper-core is far and away a better choice than than tiny platinum or iridium tipped plugs.
Hope this helps. Personally, I think Iridium TIPPED plugs are a waste of money. If you're going to 'waste' your money, buy copper-core plugs and replace them at every oil change. That add about $8.00 to the cost, but you will ALWAYS be running at peak performance levels.
Old 09-05-2002, 10:41 PM   #8
Civic
Do they still make Split Fire plugs how are they???
Old 09-09-2002, 01:41 PM   #9
fadednite
great post HondaDeuceCoupe!
Old 09-10-2002, 04:33 AM   #10
ricerX
Thanks, BDC. That was a great post. Do you know of any place to find the silver-core plugs. or approximately how much $ they are?
Old 09-10-2002, 07:33 AM   #11
Yeah, Nology sells them. Here is the URL:They're like 8 bones each. Hondas use the S3F plug. You can buy a whole set of NGK V-Powers for the price of one Silverstone spark plug...
