Old 08-16-2002, 02:54 PM   #1
krz2fer
krz2fer's Avatar
Where are Lock/Unlock Wires ??
I've found all the wires to install an alarm except the lock/unlock wires. It's a 1995 Acura Integra 4D and I can't find the info anywhere on the net. Please help ASAP!
Also, do you really need to cut open each individual wire to splice, or can you get connectors at a car shop to essentially clip-splice them into place?
krz2fer
Old 08-17-2002, 12:44 AM   #2
BrandonClaps
u can get connectors called T-Taps
Code:
| ITEM | WIRE COLOR |POL| WIRE LOCATION | | 12V|white |+ |ignition harness | | STARTER|black/white |+ |ignition harness | | IGNITION|black/yellow |+ |ignition harness | | ACCESSORY|yellow |+ |ignition harness | | POWER LOCK|black/white |- |drivers kick panel *2 | | POWER UNLOCK|black/red |- |drivers kick panel *2 | | PARKING LIGHTS +|red/black *3 | |grn plug above fusebox | | PARKING LIGHTS -|blue/red | |factory alarm (if equipped) | | HEADLIGHTS|red/wht (low) 12awg|+ |steering column | | DOOR TRIGGER|lt. green/red *4 |- |drivers kick panel *2 | | DOME SUPERVISION|use door trigger | | | | TRUNK/HATCH PIN|green |- |*6 | | HOOD PIN|yellow/red |- |drivers kick panel | | FCTRY ALARM ARM|factory remote only | | | |FCTRY ALRM DISARM|factory remote only | | | | TACHOMETER|blue | |distributor *1 | | SPEED SENSE|orange | |instrument cluster | | BRAKE WIRE|green/white |+ |brake switch | | HORN TRIGGER|gray or blu/grn |- |steering column | | WIPERS|blue & blu/yel *5 |- |steering column | | LF WINDOW UP/DN|red/blu - red/yel |A |in drivers door | | RF WINDOW UP/DN|blu/yel - blu/grn |A |in drivers door or dkp | | LR WINDOW UP/DN|green - grn/yel |A |in drivers door or dkp | | RR WINDOW UP/DN|yel/grn - yellow |A |in drivers door or dkp | | SUN RF OPN/CLOSE|grn/red - grn/yel |A |sun roof switch | | RADIO 12V|white/blue |+ |radio | | RADIO GROUND|black |- |radio | | RADIO SWITCH|yellow/red |+ |radio | | RADIO ILLUMINATE|red/black |+ |radio | | POWER ANTENNA|yellow/green |+ |radio | | LF SPEAKER|blu/grn - gry/blk | |radio | | RF SPEAKER|red/grn - brn/blk | |radio | | LR SPEAKER|blu/yel - gry/wht | |radio | | RR SPEAKER|red/yel - brn/wht | |radio | Notes: *1 Also found in a 16 pin white or gray plug to the left of the fusebox. *2 In the larger of two attached gray plugs in the lower kick near the firewall. If equipped with cruise control, the plugs are behind the module. To access, remove the lower bolt on the bracket holding the module and pull it up out of the way. The lock wires test only with the passenger lock and unlock switch. *3 Also a male blade terminal is available in fuse box. *4 Looks like 14 ga.wire but mostly insulation. *5 Use both and diode isolate each. *6 12 pin blue plug on top center of fusebox.
