Old 07-10-2002, 02:02 PM   #1
chadlicious
Need help on lowering on 4th gen. accord
I need some help on a 4th gen accord (90 coupe LX). I'm debating between springs and coilovers. Which is easier to install and which is better in the long run? Also I want to know how far can I drop my car. I want to get 17" wheels with a 40mm offset wrapped in 215/40/17's. I want to know how far I can drop the car without having a camber kit and without having the fender rub. Also, are 215's too wide? Will they be directly under the fender or will they still be slightly tucked under? Any help would be great...thanks
Old 07-10-2002, 02:35 PM   #2
i would stay away from coilovers. as for the drop you can go up to 1.8" without a camber kit, but usually they require one after 1.5". it all depends on the chassis of the car. rims with the tires that you want i don't think you will have the wheel tucked under the fender, unless you get a 2" or more drop.
Old 07-18-2002, 04:29 PM   #3
insomniac_91
why do you suggest staying away from coilovers? I was thinking of getting them only because of the adjustability.
Old 07-18-2002, 08:56 PM   #4
were you talking real coilovers or just coilover sleeves ?
Old 07-19-2002, 09:23 AM   #5
chadlicious
what's the difference? I'm talking about like $200 coilovers not the $1000 kits. So I'm assuming just the sleeves.
Old 07-20-2002, 01:52 PM   #6
yeah just the sleeves. the sleeves will make the ride stiff as hell. i got the kyb agx shocks with the eibach prokits and my car was lowered 1.5-16" and it rides and handles beautifully, plus my camber is .5 degrees after lowering
Old 07-21-2002, 11:52 PM   #7
panther314
Parked
panther314's Avatar
hey i have 17" montegi MR12 with a 40 offset ..eibach sportline so its like 2" drop it fits like a glove in the fender and 1/4 it doesnt rub at all ....1 suggestion though make sure u have the car aligned right after if not u will were out the inner tire too fast make sure the tire u use is a soft tire too or ur ride will be hard im using potenza and its smooth and quite ....with coil overs if u live where it snows or season change dont use u will only have probs with them .... hope i could help a bit ....
AS I WALK THROUGH THE VALLEY OF THE SHADOW OF DEATH, I WILL FEAR NO EVIL.
panther314 is offline   Reply With Quote
Old 07-22-2002, 08:11 AM   #8
chadlicious
Why will i have problems with the seasons? I thought it might be an advantage to raise the car during winter and drop it during the summer. What type of problems will I have?
Old 07-22-2002, 09:02 AM   #9
you will have the coilover stuck in the winter time. the thread will get rusty and become a biatch to lower and raise it. i have pro-kits with kyb agx and the ride is super smooth, plus the car got a nice look, ands the wheel is right in the center of the wheel well. it looks quite nice. maybe it's time to get some pics
Old 07-22-2002, 09:03 AM   #10
and with them the camber is still under specs. i got the sheet and i have .05 degree camber.
