Old 10-04-2001, 08:38 PM   #1
turbod97ex
Installed TurboXS MBC
I just got my TurboXS manual boost controller today. I installed it in about 10 minutes. I know, what took me so long? Well, I just wanted to make it look pretty . Seriously, all you need to do is unplug the silicone hose from the actuator for the wastegate, plug it into one side of the MBC, take the hose supplied and plug it into the other side of the MBC and then to the actuator. If you set the MBC 3 turns as in the instructions, it gives you right at 7.5 psi. I set mine to 8 psi. This is a great MBC for $80. The turbo spools quicker and there is NO spiking. I like it.
