Old 07-05-2002, 01:44 AM   #1
fadednite
Wheel offset
I wanted to get 17s for my 97 civic. What is the correct/best tire size and offset?
Old 07-05-2002, 09:49 PM   #2
90civiclxryder
205/40/17, and the rim should have around a 4o offset
Old 07-10-2002, 03:20 AM   #3
IntegraR0064
No, that's slightly too low. Do a +42-45.
Old 07-10-2002, 11:13 AM   #4
i got a 42 offset on my car and the tires are hanging a bit on the outside.
Old 07-10-2002, 11:25 AM   #5
you dont have a civic..
I wouldnt go less then a +42..
Edit: Sorry, that was a typeo..
Old 07-10-2002, 01:55 PM   #6
IntegraR0064
+40 with a 205 tire will make you rub on tight turns, guaranteed.
Do at least a +42.
I hate establishing credibility, because it makes me sound conceited, (start sounding like an ass here) but I was suspension moderator and wheels/tires moderator (other forums too) at SHO for 2 years and I've been moderating suspension and ITR forums at hondavision (much better than sho) since it began. Ever heard of "Offset 101"? I wrote it. I also know of many people who have gotten +40 on that generation of civic, and have rubbed.(end sounding like an ass here)
So.....+42-45
Old 07-10-2002, 03:15 PM   #7
spoogenet
Oh Great One of All Things Suspension:
What would be the best offset for a 6th Gen Accord sedan with 18" and 225mm tires?
Just playin with ya....but my question is foreal.
b
Old 07-10-2002, 05:26 PM   #8
IntegraR0064
Kneel, my loyal subject, and I shall bestow you with infinite knowledge
bhahahahaha.....
For you, a +42 should be good. +40 or +43 should work as well, but you may get very slight rubbing on those tight turns if you lower a lot. 225 is really wide, you don't have as much room for error...
Hope that helps
Old 07-10-2002, 08:31 PM   #9
fadednite
the wheels i want have an offset of +40. Can you change the offset somehow? I really don't want any rubbing on the fender.
Old 07-10-2002, 08:32 PM   #10
fadednite
btw... with neg camber...can't you get away with a 40mm offset without rubbing on the fender?
Old 07-10-2002, 08:50 PM   #11
One thing you have to remember is that your camber changes when you corner, you can still have rubbing even with some Negative Camber. Besides that you dont want to much camber, because thats less of a tire contact patch that youll have.
Old 07-10-2002, 09:14 PM   #12
fadednite
how about when switching from stock wheels to aftermarket back to stock....do you always have to check the camber with each wheel? or once the camber is set, it'll stay the same?
Old 07-10-2002, 09:17 PM   #13
ShEaNy
ShEaNy's Avatar
whats the best offset for my car? 91 accord... DUH lol
Old 07-10-2002, 09:18 PM   #14
IntegraR0064
Yes, with spacers. Only problem is...spacers only lower the offset. There's no reliable way to make offset more positive.
As to negative camber...yes it'll help you get away with it. How much camber are you planning on running?
And camber is an angle...changing the size of the wheel won't change it.
Hope that helps.
Old 07-10-2002, 09:24 PM   #15
IntegraR0064
btw, here is more info on camber than you could ever want:
http://www.hondavision.com/showthrea...threadid=13084 (a few posts down is where it gets meaty )
And here is more information on offset than you could ever want:
http://www.hondavision.com/showthrea...&threadid=5638
Old 07-10-2002, 09:43 PM   #16
IntegraR0064
What size tires?
Old 07-10-2002, 09:47 PM   #17
fadednite
I was planning running -1.5s
Old 07-11-2002, 09:46 AM   #18
spoogenet
bhahahahaha.....
Hope that helps
Lower how much though? When I do finally buy some rims and rework my suspension, I'm probably going with the Tein coilovers. If I don't get those as a present or don't want to blow the cash myself then I'll get Eibach Pro-kits. With the Teins the minimum drop is something like 1.5" in the rear and 1.35" in the front....I don't see myself ever lowering it more than 2" in the front since I do need good speed bump clearance around town.
I'm looking at 225/40/18, and I've even been told 19" are fine on the 6th gen, but I guess that really depends more on how much I'm lowering.
So I guess until I hear otherwise I'll plan on +42. I'll be sure to check out the thread you posted when I get some time.
b
Old 08-09-2002, 02:08 PM   #19
2000civicexcoupe
I got +45 offset on my 18" konig tantrums wrapped with 205/35/18 size tires. How much do I lower it for it to look good and not rub??
