Old 07-03-2002, 10:19 PM   #1
SilverCoupe2K1
"Accord Emblem"
Just to confirm, the "Accord" emblem on the 6th gen is in fact held there by glue (double sided tape).
I know for a fact that the H is inserted with 2 pins...I'm fairly certain that the "Accord" is glued...am I right?
Also, any recommendations for taking that as well as a sticker off?
I was planning on simply heating it with a hair dryer and using a credit card or dental floss...any suggestions or experience would be appreciated...thanks.
(Hey look at me...I'm in second gear!)
Move over world!
Old 07-04-2002, 12:39 AM   #2
you got it all figured out. now get to work you lazy bum j/k
Old 07-04-2002, 09:53 AM   #3
SilverCoupe2K1
Yessir Captain (Rice that is...)
Old 07-07-2002, 02:46 AM   #4
accordboy00
ues, the emblem is held on with glue, not pins. I just removed my "accord" a couple of months ago. I didn't use a hair dryer because it takes too long to heat. Instead I put my car out in the sun for a little bit and the wire cut right through the glue. If you do it good enough you can get most of the glue off with the wire, just hold it as close to the paint as possible. Removing the remaining glue is the hardest part. Use WD-40 or adhesive remover. Since then I've removed my "LX" and the "eclipse GS" off my GF's 2000 Eclipse.
