Old 06-18-2002, 11:32 PM   #1
vtecmansi
ecu code 61
on my 2000 si my check engine light came on so i checked the ecu codes. its giving me a code 61 which is the primary o2 sensor circuit. the wiring looks fine so does that mean i need a new o2 sensor? seems easy but i just didnt know if that was actually what could cause the circuit bad code!
Old 06-20-2002, 12:45 PM   #2
midjjj
did you make any intake or exhaust changes? I am having a similar problem now and am trying to fix it. If you didnt make any changes, then it may have gone bad, but it seems weird for one to go bad like that, esp so quickly.
Old 06-20-2002, 04:44 PM   #3
vtecmansi
changes
yes i put a new skunk2 intake manifold on about a month ago. it stutters mid power band pretty bad now too. about 4k rpm it will lose power then build back up when i hit the gas. i though it was a vacuum leak but now that the ecu is saying its the o2 sensor and also my exhaust is extremely black with soot. i know exhausts are suppossed to be black but mine is really chuncky with soot. if ya have anymore input it would be appreciated
Old 06-20-2002, 06:21 PM   #4
blownteggy
check your MAP Sensor. or anything loose around the manifold
Old 06-22-2002, 03:59 PM   #5
okay, here's a simple fix. i had this problem before 5 months ago. all i did was pull out the sensor and cleaned it with a hot soapy water. the CEL never came back.....knock on wood....
Old 06-22-2002, 04:01 PM   #6
always reset your ECU on any major upgrade you do with your car. YES, that includes intake and exhaust systems.
Old 06-22-2002, 04:20 PM   #7
vtecmansi
yeah i reset the ecu. tried it like 4 times and 4 different methods...ie. let it idle for 15 min. and so on. ill try the hot soapy water this week. hopefully it will work. just any soap or did you use dish soap or what??? thanks!
Old 06-22-2002, 08:31 PM   #8
dish soap, to get rid of any oily build up crap on it. rinse with water and dry it up thoroughly with a dry cloth.
Old 06-24-2002, 01:16 AM   #9
midjjj
hey, let me know if any of this works ok? thanks
Old 06-28-2002, 07:36 AM   #10
vtecmansi
no
nope didnt work. while i was under the car though i could feel a pretty good size exhaust leak just behind the cat. i dont know how much this could effect the stuttering or the ecu code but according to my sources a code 61 can also be an exhaust leak. soooooooo im gonna get the leak spot welded this weekend and if that doesnt fix it ill put the new o2 sensor in and then from there i guess its on to the timing. exhaust leak looks to be the obvious cause though.
