Go Back   HSTuners > Honda / Acura Cars > DC5/EP3
Old 09-30-2001, 09:37 PM   #1
2fcknfst
Oil Catch can and 68mm TB
Installed my oil catch can and revised 68mm throttle body this weekend.
I am curious if there is anyone else out there who a) has an ITR, and b) uses the Holley 68mm TB.
I am having a problem with idle dwell, i.e. won't come back to idle when I release the gas, and I am not quite sure about what would induce this characteristic.
Any input would be appreciated.
Cheers.
Old 10-08-2001, 03:13 PM   #2
2fcknfst
I have now removed the replacement 68mm TB from Holley.
It appears that there is some fundamental design difference between the 2 which will not allow my idle to settle down between shifts and when I come to a stop...
Very puzzling because the moment I put the old one back on, this problem ceased to be a problem.
Old 10-08-2001, 11:38 PM   #3
slowerthanu
Kind of sad after paying so much money eh.
I think I will go SPOON TB, I like the conical design, should increase velocity.
Old 10-09-2001, 03:47 PM   #4
2fcknfst
Yes, it MAY improve velocity but it will not increase volume due to the venturi being the same size.
I believe that people have realized moderate gains with this piece, but not worth the money.
Pull yours and machine it yourself.
I did originally. Worked well.
Old 10-09-2001, 04:42 PM   #5
slowerthanu
The main reason I like the SPOON is because of the fact that it is a brand new TB complete with New TPS and MAP sensor, this would allow me to sell my old Type-R TBfor about the same amount I bought it for.
But I do agree with you on the Venturi part, I really do not understand why the didnt increase the venturi to say 68mm and then have it expand to 70mm at the inlet.
Old 10-09-2001, 05:16 PM   #6
2fcknfst
I believe it screws up the calibration on the stock map sensor. This would partly explain some of the problems I am having with the Holley 68mm TB.
