Old 05-08-2002, 09:50 PM   #1
1990CivicSi - nice place for 6x9's
Me and my friend had a great idea one day for rear audio in my 1990 Honda Civic Si Hatch. The little plastic indentations that come stock on the car are not big enough for anything. So that poses a problem for 6x9's. Here is the answer:
The back rack/shelf thingy (i dont know what it is called) is made of cuttable material. I would suggest using a jigsaw to cut into it, but any method works. Just make sure that you don't cut a hole too large or you are SCREWED.
What you'll be doing is making a clearance hole for the magnet of your speaker. You'll just set the speaker down in there, secure it with a few wood screws or whatever (you'll need a drill).
If you want to be real fancy you can cover the sides from view using wood blocks or plastic. We got good results with painted wood. Then just make a trip to Radio Snack and pick up some cheap 6x9 covers. We also invested in a pair of panyhose to cover the 6x9 with to protect it from any debri that may get in there.
Make sure you cut just enough clearance out of the shelf so that your wires to your speakers still fit. Also, postion the speakers as far to the sides as possible, because if they are in the middle it will bow the shelf. As it is, you may need additional support if a squaking starts happening.
