Old 04-25-2002, 06:51 PM   #1
onebad90accord
heart beat sound
My system is making a heart beat sound......????I dont know whats going on I checked my RCAs and My ports in the back of my stereo....I dont know any suggestions???........
Please help!!.....
Old 04-25-2002, 08:18 PM   #2
I'm assuming your subs are "pulsing." Take a look. It's probably your amp. I would bench it and go from there.
Old 04-25-2002, 08:18 PM   #3
is it a regular sound?
and thru which speakers is it coming?
Old 04-26-2002, 01:53 AM   #4
Maxvla
doh! its alive, its alive!!! ITS ALIVE!!!!! (evil genius scientist voice)
not really. your amp doesn't have a warm up cycle... which means. when you turn the key on or off it thumps cause its immediately on letting any little distortion put through to the subs to be played.
you really don't have anything to worry about, unless... its doing it while playing regularly (not turning the key). then you've got some weird stuff going on!
the thumps won't damage your speakers, usually so you'll just hafta endure getting thumped on a regular basis... if its just insanely loud thumps that might damage so have it looked at if thats the case.
Old 04-26-2002, 09:56 PM   #5
black95gs-t
black95gs-t's Avatar
the amp could be malfunctioning, or you just ran your rca's too close to a power source and when the power initially surges through the source, it also goes through the rca's making the noise. what kind of amp is it? brand and model
LOONEY TUNES!!!!
Old 05-02-2002, 02:41 PM   #6
onebad90accord
its a pyle 800 watt amp...I think it migh be my stero then
Old 05-02-2002, 03:07 PM   #7
Maxvla
umm... pyle? i bet its the amp.
Old 05-02-2002, 04:29 PM   #8
2000Pimpinex
Super Moderator
2000Pimpinex's Avatar
Could be the amp, but you can just put a relay on it so it won't come on as soon as you turn the key/stereo on.
2008 Mustang GT
1998 Hatchback SOLD
1985 Ford Bronco XLT 5.8 351W
w/ 33X12.5X15
Old 05-05-2002, 11:46 PM   #9
Quist
your stereo is putting off a slight sound through your amp(normaly not percievable) but the amp (obviously) amplifys that small current and you will hear it through your subs, try turning down the gain on your amp and see if that helps it. When you turn your car on and off does it thump??? If you answered yes then you will need to get a new deck probably. The sound is not damaging to your subs so there is no hurry its just really annoying.
Good luck
Old 05-07-2002, 02:55 PM   #10
ddr_max
yeah it sounds like the amp i had a amp that did it it was dead
Old 05-10-2002, 12:04 AM   #11
black95gs-t
a more likely cause than the explination that quist gave would be, if the inputs of the amplifier are not attached properly, they will cause this sound. the most likely source is the amplifier itself. amps are not too expencive to fix. usually it is a pretty cheap part that breaks. but since it is a pyle, you could probably afford a new amp for the price of the fix.
J
LOONEY TUNES!!!!
