Old 04-24-2002, 11:36 AM   #1
Fatal070
Fatal070's Avatar
what the *ELL
when drivein it feels like my back tires are running over something but there not i dont' know what the hell this is might be the tires there pretty bad there cracking but im just wodering if it might be the rim what do u think?
Old 04-24-2002, 10:51 PM   #2
spoogenet
The belt could be broken in one or both of your back tires. I would look into replacing the tires, if that's the case. A buddy of mine had that problem in the front wheels of his '93 Accord, at slow speeds the steering wheel would wobble a bunch, as if the tire were not fully bolted on. At higher speeds it would have a very slight vibration, like a wheel being out of balance.
b
Old 04-24-2002, 11:01 PM   #3
or check your balljoints.
Old 04-25-2002, 08:57 AM   #4
spoogenet
Are there balljoints on the rears? I ask cuz I don't know, but I've never heard of them on the backs either.
b
Old 04-25-2002, 11:05 AM   #5
well i don't know about sol's but on my accord there is one from the upper arm to the rear knucle. Also shocks might be blown.
Old 04-25-2002, 02:39 PM   #6
ShEaNy
ShEaNy's Avatar
I had the same problem when i was stopping.. The steering wheel was everywhere! .. i had too two hand the thing to stay in my lane! I got my brakes replaced thinking it was just the pads or something and it stopped..now months later its happening again!...
Old 04-25-2002, 05:45 PM   #7
how are your engine mounts ? what about your shocks ? how are the front hub bearings ? all this cause these symptoms in a car
Old 04-25-2002, 10:30 PM   #8
spoogenet
Well if it stopped, then returned, I would think it has to deal with your brake system since you replaced some of it. Did you replace the rotors, or just the pads?
b
