Old 04-10-2002, 04:15 AM   #1
seanjuan
running wires into door panels
now that it is getting warm again i will be finishing the install of my alarm system. before winter kicked in i got everything but the power lock wires hooked up. i know that i need to send two wires into the drivers door panel in order to conect them to the power lock module in my 92 lx
what i'm wondering is if anyone knows of a good way to do this?
i'm most likely just F with it untill i find a way to do it, but i figured it couldn't hurt to through the question out
later
Sean
Old 04-10-2002, 06:21 PM   #2
BrandonClaps
well if u got an anti theft, you can find the wires there. Otherwise, get one of those huge zip ties and drill some holes in the end of it (not the lock side) drill holes the size of the wires and fish it thru and put the wire thru and tape it up good and pull it back...
Old 04-10-2002, 06:46 PM   #3
seanjuan
that's a good idea, i usually use a coat hanger or some type of wire, but it's hard to attach the wires to that
thanks for the tip
Sean
Old 04-10-2002, 11:14 PM   #4
BrandonClaps
n/p
