Old 03-17-2002, 11:05 PM   #1
renahec
Intermitent Front End Shake
Hi,
hope someone can help me.
i have a 1994 prelude si that seems to have a really horrible shake or wobble coming from the front end and through the steering wheel at speeds over 55mph (left to right, not up and down) sometimes it's worse than other times and sometimes it's so bad that it makes the whole car shudder!
i have replaced the tires with brand new bfg's and brand new ar rims. i just recently had the front end re-balanced but it is still the same.
when we bought the car the rear brakes and rotors were totally wasted and i replaced the calipers, rotors and pads on the rear.
i imagine it could be possible that the front rotors have been warpped from being over worked. the fronts are being replaced this week though.
does anyone have any ideas? any help would be greatly appreciated.
thanks ..............Hec
Old 03-17-2002, 11:08 PM   #2
tierods, and balljoints. also you might have a bent rim causing this.
Old 03-18-2002, 02:16 AM   #3
How does braking or accelerating affect it?
What happened to mine is I had one of the upper wishbone mounts come loose. That sucked.
