Old 03-16-2002, 02:44 AM   #1
Wookie
Block pics!!! Look quick, don't know how long they'll be up!
Block built by www.leitnerbush.com
LS - B18B block with Eagle rods, SRP pistons (9.2:1), JE rings
Re-sleeved with ductile iron sleeves with solid blockguard welded in then the block is decked and guard is drilled for coolant passage.
Cylinder head is a B16A with GSR cams and AEM adjustable cam gears.
I will be running a Hondata Stage 2B with the GM 3-Bar map sensor and 720cc Injectors.
Should be finished in about a month. Looking for 350+WHP at 15 PSI.
