Old 03-15-2002, 04:58 PM   #1
hondabob
Ignition of fuel computer?
Which should I purchase next. A apexi fuel/vtec controller, or a MSD SCI with rev limiter? I have only I/H/E and will get turbo in future. Help please? What is the next logical step?
Old 03-16-2002, 03:14 AM   #2
A V-AFC won't do anything without first upgrading your camshafts. The stock fuel map is optimized for emissions and power, and the stock VTEC crossover point is optimized for the camshafts. Stock camshafts= ZERO gain from a V-AFC.
An ignition won't do a whole lot of good, either. It may make your car idle a little smoother, but gains will be minimal, if at all. And why get a rev limiter? Your stock ECU already has one. You only need the limiter on the ignition if the ECU doesn't have one.
With an I/H/E, planning to go turbo, I'd just save for the turbo. Anything else you could do would be money wasted either before or after it arrives. By this I mean gains would slim to none until the turbo is added into the equation (ignition, a/f controller), or they would be useless or detrimental once the turbo is installed (intake, header, camshafts).
I was in the same boat- trying to decide what I wanted to do in the mean time while I planned to turbo sometime in the future. There's not a lot, and if you did every bolt on in the book, you still wouldn't get anything impressive. My advice: quit buying bolt ons, and save for your big power adder, whether it be turbo, all motor, a swap, or whatever. I wish someone had told me that a couple thousand dollars ago.
Old 03-18-2002, 03:39 PM   #3
MSD 6AL
-Save yourself the money. The SCI-L is an identical unit (minor voltage drop).
Make sure you upgrade the coil & wires too......
