Old 03-14-2002, 02:03 PM   #1
Wallythecat
Windshield Washer Pump?
I'm new so wait a few days before you all do something terrible to me...
Anyway, I just got a "new" 95 Civic EX coupe and slowly working up the courage, funds and know how to modify it.
Starting slow, the only thing I've found wrong with it is the windshield washer pump doesn't work. I replaced the pump, checked the fuse and everything appears to be ok. I checked the wiring harness and it doesn't appear that there's any current coming through. Just wondered if anyone else has had a similar problem. I'd hate to start tearing out wires and stuff if it's something simple. Any ideas?
Old 03-14-2002, 03:19 PM   #2
is the lever working ? check every single fuse because honda has some weird circuits. if i take out the radio fuse my windows and interior lights will not work if the key is not in the on position.
Old 03-14-2002, 03:26 PM   #3
Wallythecat
I'll check the fuses this evening... I can't find anything else that doesn't work, but what the hey. I assume the lever does work because when you pull down on it, it does activate the wipers...
Thanks!
Chris
Old 03-14-2002, 07:01 PM   #4
Yeah, check more fuses, and let us know if that takes care of it.
Old 03-15-2002, 08:13 AM   #5
Wallythecat
I checked all the fuses and they were all fine. I think the plug was messed up on it, so I bent the connectors a bit, plugged it back in and it works!
Thanks for all the suggestions!
Old 03-15-2002, 08:20 AM   #6
Good Job man... Welcome to HS!
Old 03-15-2002, 06:15 PM   #7
Glad you got everything figured out, but sorry you bought a new pump first :o
