Old 03-10-2002, 12:08 PM   #1
C's 94 InTeGrA
C's 94 InTeGrA's Avatar
Need HELP fast think my clutch just went out!
Ok well since yesterday i have noticed my clutch feeling funny when i drive it. when i would let it in and out it would come out faster than it did and i thoughti it might just be stupid me. well when i went to pull it in last night i was tryign to get it in 1st gear and it wouldnt go.. i had to force it.. and it would grind a little. then i tried reverse and it did the same and this time when i let the clutch out it did the same come out really fast but it acts like it catches on something. has my clutch gone bad and do i need to replace it? i got 127,000 miles on the car i dont know if it has ever been replaced but it just started this? i need help fast!
Old 03-10-2002, 02:37 PM   #2
That sounds very similar to when my master/slave cylinders went out. You might want to check those before you replace the clutch.
Old 03-10-2002, 03:52 PM   #3
That doesn't sound like the clutch. You know when the clutch has gone out- You'll let go of the clutch, push the gas pedal, and the RPMs will go up, but the speedometer won't.
Are you leaking transmission fluid? You may need to fill that up and/or bleed the lines. Sounds to me like you've got bubbles in your lines.
Old 03-10-2002, 10:44 PM   #4
C's 94 InTeGrA
Ok i found out my problem!!! there was not a drop of clutch fluid in the container! i havetn a clue why and there is not spots on my floor from it dripping so i duno how it got lost... but thanx anwyays guys...
Chris's 94 Teg
Old 03-10-2002, 11:03 PM   #5
Glad you found an easy fix to your prob. Now you just have to hope their isn't a crack or some kind of leak in the system...
Old 03-10-2002, 11:39 PM   #6
C's 94 InTeGrA
Why is that bad? expensive? i hope not either cause all my monmey now is going to my system and i dont want to use that..
Chris's 94 Teg
Old 03-11-2002, 12:43 AM   #7
I was just saying I hope you don't have any leaks or anything for simplicity's sake. If your master/slave are fine, I don't think you'll have any probs. Just keep checking the fluid regularly in the mean time.
