Old 03-04-2002, 02:34 AM   #1
SlikVic
New MOMO pedals
I finally installed these pedals
they look good and feel great
i am so happy
Old 03-04-2002, 03:18 AM   #2
Looks great. I'm glad you got everything figured out.
Old 03-04-2002, 02:31 PM   #3
Hey those do look alright....I would buy a set if I wasn't selling my car.
Old 03-04-2002, 02:52 PM   #4
Quick question: How do they feel when driving? Also, I thought they'd be a little closer together so you can heel-toe easier. What are your overall impressions of them?
Old 03-05-2002, 12:20 AM   #5
you need to vacuum in that car jfwy
Old 03-05-2002, 02:06 AM   #6
SlikVic
i am so happy with them.
You are right about the heel toe
However later on i will probably move the accelerator closer to the break. that will probably make it an inch closes
Old 03-05-2002, 02:22 AM   #7
So the position just depends on where you drill the holes? How would you move them?
Old 03-05-2002, 08:49 AM   #8
BrandonClaps
drill the holes? u had to drill holes into your stock pedals? Through the metal? How hard was it to get thru? I wanna see how close u can get it cause i wanna be able to heel toe
Old 03-05-2002, 08:53 AM   #9
BrandonClaps
oh wait i saw in your other post u had to weld the accel pedal on? Yucky i don't wanna do that! ;[
Old 03-06-2002, 12:38 AM   #10
SlikVic
no!! i didn't have to get it welded!!!!
I used self tappers in the accelerator instead.
It is not so difficult to drill through the metel, it is just getting down their to do it.
You can move the pedals as close as u want, however it u do it to close then you will see the old stock plates around the edge.
i ended up pulling the bottom part of the dash of to get more room. another alternative is to take out the seat!!!
you have got to get some they are worth it and are great!!!!!!
Old 03-06-2002, 09:59 AM   #11
BrandonClaps
how well did the screws go in? and how well does it hold up?
Old 03-07-2002, 01:32 AM   #12
SlikVic
i have absolutely no problems, i thaught they may fall off but they are just as strong as the bolted on ones!!
Old 03-10-2002, 06:52 PM   #13
SlikVic
The Japanese Honda Civic Type-R brake and gas pedals are 60mm appart from edge to edge, my momo pedals are 63 to 64mm appart. so they are set up for some nice heel toe action!!
Old 03-10-2002, 09:32 PM   #14
BrandonClaps
they are as good as the bolted ones? what you mean bolted?
Old 03-12-2002, 08:53 PM   #15
Azkikr111
man, i'd rather get some cheap ones that just kinda buckle or attach themselves on, i dont like the idea of drilling any holes in my car, whatsoever
Old 03-13-2002, 12:26 AM   #16
SlikVic
you drill through the pedal
you place the momo pedal on top
you shove the screw through the pedal the the hole
You get the nut and tighten it.
the brake and clutch are like that and the acclerator is selftapped in. They are all bloody strong.
Old 03-31-2002, 02:14 PM   #17
gee
hey.. quick question..
how do pedals affect driving? is it just the feel?
Old 04-01-2002, 07:02 AM   #18
SlikVic
yes, for me its just the feel, but the feel great!
the advantage with them is that if you want, and i did, the pedals ended up closer together.
