Old 03-01-2002, 03:41 AM   #1
Exclamation Why You Should Use Honda Coolant Only...
Originally posted by Nexus242
I can't imagine Prestone, Zerex or Peak would cause erosion of your inner gaskets even if they are Honda gaskets. Just stick with a top name brand and you should be alright with no leaks.
I cannot help it if you have a lack of imagination, Nexus. Besides anybody into debating knows this playground ploy to be the "argumentum ad ignoratiam" or "appeal to ignorance" fallacy, e.g. Nexus242 can't imagine something is true, therefore it must be false. Please!!!
Let's play fair. I'll provide you with evidence and you dispute it. That way you can't plead ignorance or lack of imagination...
SOURCE: Any Honda Dealer Web Site
Why must I use Honda-brand antifreeze/coolant in my engine/radiator?
  • Most coolants labeled safe for aluminum engines actually aren't. The silicates and/or borates added to most coolants act as abrasives on the cooling systems.
  • Honda's formulation for coolant does not use silicates or borates to enhance the corrosion protection for aluminum components. Instead, Genuine Honda antifreeze/coolant uses a proprietary organic corrosion inhibitor.
  • The advantages of the Honda coolant are clear. Its ability to inhibit corrosion and the absence of silicates makes it the only coolant recommended for your Honda.
  • If Genuine Honda antifreeze/coolant is not available, you may use another major-brand non-silicate coolant as a temporary replacement. Make sure it is a high-quality coolant recommended for aluminum engines.
  • However, continued use of any non-Honda coolant may result in corrosion, causing the cooling system to malfunction or fail. Have the cooling system flushed and refilled with Honda antifreeze/coolant as soon as possible.
And, of course, here's the infamous Honda Corp letter written to its' Honda and Acura dealers:
Genuine Honda Coolant is the Only Way to Go
Increasingly severe operating conditions and the advent of lower maintenance requirements have resulted in significant changes in the variety and the concentration of additives used in engine coolant. Also, the continual improvements in engine and vehicle design have challenged coolant suppliers to design products that perform well in a more demanding environment.
To meet these needs, Honda engineers have developed a superior, high-quality coolant that has several advantages over the competition.
Some antifreeze, although labeled as safe for aluminum parts, may not be compatible with Acura cooling system components. Extensive research and testing by both Honda R&D and CCI, the manufacturer of the Honda coolant, have proven that the abrasive silicates and/or borates found in most domestic coolants can cause these problems:
  • Silicates bond to the surface of the water pump seal and act as an abrasive, causing considerable seal erosion and coolant leakage.
  • In actual tests, the silicated coolant caused early leakage. This leakage increased dramatically until a substantial portion of the coolant had been lost.
  • In contrast, the Honda coolant had almost no leakage through the duration of the test.
There was a chart here, entitled "Coolant Leakage from Water Pump Seal", showing Leaked Coolant Volume in ml as follows for each test duration in Hours. This is the text:
Time
Honda Coolant volume leaked
Typical Silicated Coolant volume leaked
24 hours
0 ml
21 ml
48 hours
1 ml
36 ml
72 hours
2 ml
47 ml
96 hours
2 ml
55 ml
120 hours
2.5 ml
56 ml
144 hours
3.5 ml
57 ml
168 hours
4 ml
58.8 ml
192 hours
6 ml
63 ml
200 hours
6 ml
64 ml
  • Silicates tend to gel and settle in the coolest parts of the cooling system, causing radiator plugging and overheating.
  • Borates cause pitting corrosion on the cylinder head.
  • Silicate inhibitors are difficult to stabilize and, therefore, limit coolant shelf life.
Most commercially available coolants were originally designed for cast iron engines. Silicate, an inexpensive additive, was added to coolants to prevent aluminum corrosion, but the long-term durability of the combination was not tested.
In contrast, Honda coolant was designed specifically for aluminum engines. It contains an organic corrosion inhibitor instead of silicate. This superior formula gives these advantages:
  • No silicate abrasion of water pump seals. For example, these graphs show the surface roughness of two aluminum water pump seal rings. Seal A, exposed to silicated coolant, shows considerable damage. Seal B, exposed to Honda coolant, displays only minute wear.
  • (graphs here, showing roughness across the surface, with A a very wiggly line, and B a very smooth line)
  • No plugging or overheating caused by silicate gelling.
  • Excellent corrosion protection for aluminum components.
  • Long-term corrosion protection for other cooling system materials (steel, cast iron, copper, solder, gaskets, seals, and O-rings).
You can find less expensive coolants on the market, but now you can see why genuine Honda coolant is the only coolant approved for Honda and Acura vehicles (it MUST be used for warranty repairs). Honda's non-silicate formula delivers added protection not offered by 95 percent of other brands. Since our customers expect lower maintenance, you're doing them an injustice if you use any other coolant.
Okay, dispute away, bro... :o
