Old 02-26-2002, 11:13 PM   #1
SweetAccord
Instructions to install coilovers
My friends are going to install coilovers (Teins) for me on Saturday and they wanted to know if anyone has a repair and/or manual or there is a site where there is instructions to install coilovers for the 6th gen Accord specifically. I need instructions to install the camber kit too. If any of you have time to post the directions on here it would help us greatly.
TIA
Old 02-27-2002, 12:48 PM   #2
what kind of chamber kit do u have ?
as for the coilovers it seems to me that it is just as a suspension change: unscrew the 3 bolts on top (in the engine may or trunk 2) and then the bold in the control arm and the suspension should come right off. then put them in reverse order. you will know about what i am talking about once you take the wheels off
Old 02-27-2002, 10:56 PM   #3
SweetAccord
I got ingalls camber kit.
Old 02-27-2002, 11:04 PM   #4
does it look like the upper arm ? i'm not too familiar with that but if it is like the upper arm you got 3 screws to undo and redo (in my 92 accord)
-one should be the upper ball joint
-2 will be under the hood of the car around the strut screws. you even don't need to remove the shock to remove the arm
Old 02-27-2002, 11:46 PM   #5
SweetAccord
do you know how i can lubracate the camber or what I can use? it's polyurthane(sp?)...I heard that I'm supposed to lubracate it.
Thanks for you help
Old 02-27-2002, 11:52 PM   #6
Thanks for you help
np about the help. i just went out to my car and took a look at it. i don't know about the lubrtication thing but any bushings shoud come pre-lubricated.
btw it's polyurethane
