Old 02-16-2002, 09:56 AM   #1
DJZVTEC02
Exclamation 6th Generation Civic Skunk2 Camber Kit Install
Tools Needed
-14mm Wrench
-17mm Wrench
Parts Needed
**Removal of the shock body is also NOT needed**
-Skunk2 Camber Kit (Front)
-First remove your wheel and jack the car up
-Then Remove the 2 14mm Bolts holding the A Arm inplace
-Then place a deep socket 17mm Wrench and remove the castle bolt holding it in place
-Remove A Arm
-Install Skunk2 Unit
-Bolt everything up and install those little pins (codder pins) that they give you and wrap them around the castle bolt and this is what it would looks like after your done..
