Old 02-15-2002, 01:31 AM   #1
xunkn0vvnx
Replaced Brake Pads and its STILL SQUEAKING !
I am having brake pad problems on my 94 honda accord EX. I am currently using Raybestos brake pads all around and i just changed the brake pads 100 miles ago and it just started squeeking again... Are these brake pads bad, should i just go back to the stock brake pads ?? WHat can i do to get rid of the noise
Old 02-15-2002, 01:57 AM   #2
Did you give them time to break in? They need a little bit of time before you should stomp on them.
Old 02-15-2002, 07:24 AM   #3
if you put that lining that goes on the back of the pad wrong and the pad will not step right on the disk it will never stop. make sure the pads are straight, or your car will sound like a bus when braking.
Old 02-15-2002, 11:39 AM   #4
It may also be that the pads are part of a somewhat faulty batch..
Too much of the metal stuff in there..
Old 02-15-2002, 12:12 PM   #5
true very true. i almost forgot obout that.
Old 02-15-2002, 01:37 PM   #6
SWIFT
did you apply anti-squeel gel on the pads?
Old 02-15-2002, 05:17 PM   #7
xunkn0vvnx
No i did not apply that... Is it too late ?? What can i do now to fix the problem ?? I doubt it is faulty pads... How do you apply that anti squeel
Old 02-16-2002, 12:15 AM   #8
SWIFT
you have to apply it on the back of the pads (facing the caliper). it will prevent vibration on the pads and so the squeeling..
i think if you go to autozone it's called Permatex Anti Squeal or something..
you should always do this when you replace your pads... goodluck
Old 02-16-2002, 02:35 AM   #9
xunkn0vvnx
ill try anythign right now... thanks alot everyone
