Old 02-08-2002, 12:59 AM   #1
Maxvla
Clear Side Marker Install
im thinkin about getting some clear corners... but ive never changed lights b4...
whats the process and how long should it take?
i only have about 2 hours at a time to do anything. i have a weird schedule, yes.
Old 02-08-2002, 04:00 AM   #2
azn_nite_ryder
it took me 45 mins to install mine....
if you're not electronically inclined then you might run into some problems.....
as for install its pretty easy... usually you take off the wheel liner and splice the wires from there depending on how you want your lights to work....
other than that... its a piece of cake...
Old 02-08-2002, 08:41 AM   #3
Re: Clear Side Marker Install
Originally posted by Maxvla
im thinkin about getting some clear corners ... but ive never changed lights b4...
Clear corners or side markers??
azn_nite_ryder gave you the how-to for the side markers..
Old 02-08-2002, 10:02 AM   #4
you have a 4th gen right ? Just pop up the hood, and there shoud be a screw near the top of the headlight. unscrew than and then with a flat screw driver, between the corner light and the fender and just pop it off. you will have to turn the bulb sockets like 1/4 of a turn and they will come off. get the new light and put it in. if they are some cheap lights you might have some alignament problems. you just gotta take your time to align them and you will be all set. after the alignament just screw the thing near the top of the headlight. Total time 15 minutes.
Old 02-08-2002, 11:02 AM   #5
Are you talking about side markers, where a light doesn't already exist? If you're talking about replacing stock lights, 10-20 minutes max.
Old 02-08-2002, 01:11 PM   #6
Maxvla
well i meant the turn signals... anyways.
15-20 minutes is definately doable.
thanks guys.
Old 02-08-2002, 01:34 PM   #7
Except if its stuck real well..
In which case you should spray som WD-40 a few minutes before the operation.
Old 02-08-2002, 08:33 PM   #8
Maxvla
point taken.
we'll just see what happens.
Old 02-08-2002, 08:37 PM   #9
point taken.
I thought the red Accord in your avatar was your ride.. guess not..
Old 02-08-2002, 09:05 PM   #10
Maxvla
nope... just a pic i found floating in cyberspace.
looks decent.
as soon as i get a dig camera or scanner i'll try to get a pic of my real car for avatar. and definately post pics of my car. even though its pretty stock at least i could show my humble stereo system install.
>>Later>>
Old 02-09-2002, 02:50 AM   #11
azn_nite_ryder
ahhh so now this guy tells me...
i thought by the title that you wanted side markers....
oh well
by in that case yea it should take about 10-15 mins to put those corners in....
Old 02-09-2002, 02:56 AM   #12
Maxvla
sorry bout the confusion... thanks anyways.
