Old 11-07-2006, 12:02 PM   #1
injectors
What is the diffrence between "Saturated" and "Peak and Hold" injectors?
any help will be appreciated.
thanks
mike
sorry for the noOb q's
Old 11-07-2006, 09:59 PM   #2
Didnt we talk about this already? Look it up bro.... it's somewhere in here..... peace!
Old 11-07-2006, 10:11 PM   #3
saturated uses the same ammount of voltage to hold the injector open, while peak and hold uses the same ammount of voltage as saturated injectors to open, but once it's open, the computer stepps down the voltage level to "hold" the injector open. The advantage is that they run cooler. So saturated injectors have higher resistance values, which is why if you want to run DSM's or any other peak and hold injector, you need a resistor box to raise the resistance of the injector circuits so you don't burn out your computer.
Old 11-07-2006, 10:20 PM   #4
so what are you guys using?
Old 11-08-2006, 01:07 PM   #5
P&H.... always..... easier to control duty cycle based on its characteristic...
